Have recently installed a v simple arrangement to heat my hot-tub. I have a solar water heater panel on the roof of my garage next to the tub, a pump to circulate the water and a 12v 10w pv panel to power it. When the sun comes out the pump starts and when it goes in it stops. V simple & it works - except for one problem. When there is low solar energy, the pump is activated but does not pump - it just buzzes which of course will burn the motor quite quickly. Can anyone tell me what I need to control the power - to cut off power to the pump if not enough energy and preferably limit the max power too.
The pump is rated at 12v but the manufactures say it will work fine between 9 & 14V
The PV panel is 12v /10w
Many thanks if anyone responds!
