Introduction: First time visitor. Retired Navy Corpsman having proudly served half of my career with the “Corps.” Not much of a goat farmer these days as not enough time to irritate politicians and raise goats at the same time.
I am also not electrical savvy so be gentle!
I have a Flojet Model 2100-738, DC, 7.0 Amp, 12 V http://www.pumpagents.com/pdf/FlojetPumps/02100-738.pdf at one time was powered by a couple of small now very corroded panels . I need to replace the energy source.
The system is to heat an outdoor hot tub using an existing 4’x8’ roof-mounted solar water panel. Everything worked great until the tub went unused for 3 or 4 years. Now, the best as I can tell there is no power to the pump and looking at the panels I suspect they are the problem.
Per the pump specs doc, the current for the 12 V is “8.0 amp max.”
Okay here are my questions – yes, honestly these are legitimate questions. Inasmuch as there is nearly 40’ of cable from the panel directly wired to the pump, will I lose power between the two, which may necessitate getting a panel greater than 8 amps?
Will someone offer an example of a solar panel that will provide for my needs? The wife now wants to use the tub, I do not want to pay the power to heat it, and I am losing the discussion.
Thanks,
Thanks,
