How many degrees warmer do solar heaters get the water?
skeeterComment
You will want to try to match the flow rate through all 4, so if it were me, I'd make sure that the run that's fed in closest to the pump has it's output be farthest.
ex:
Code:from pool >--------- | | | | ----------> to pool
In general the more water you put through the pipes, the more energy you can extract, so 4x250 in parallel is probably better.
(the downside is that requires a manifold/tees - which are extra expense and are going to reduce the flow some.
Good luck.Comment
I would recommend reducing your coils to 180' to 220' maximum per panel. You are probably maxing out on thermal absorption and not picking up any more heat. Reducing each coil to about 200' and having about 4-5 coils in parallel should help increase your pool temp.
skeeter
There are valid reasons to do shorter coils in parallel - but "maxing out" isn't one.
IF there were some reason that it'd "max out" when the water was 78, then if your pool was up to 78 even with multiple coils in parallel you wouldn't be able to heat it more.
Increased water volume throughput is a valid reason to go with shorter but in parallel.
And there is probably a benefit of more heat transfer because the water temp diffference is greater.
But saying it's "maxed out" is over-simplifying things to the point that what you're saying is wrong.Comment
Is 70' going in a solar panel and 78' going out typical?
Is 70' going in a solar panel and 78' going out typical? Is shortening from 500' to 200' going to increase that output 8'? Would we need a bigger pump (current is a 5gpm) to to push the multiple runs?
Thanks for all the good information!Comment
I think you will need a bigger pump. More GPM and less temp rise is usually the normal. If you can push enough water through to only get a 2' rise in temp your end result should be a higher pool temp. In layman's terms.
skeeterComment
On an average a properly designed solar hot water system may heat up your water upto 75 degrees C / 170F. On Some Summer days it would be couple of notches more, during some winter days it may not heat at all!Comment
I noticed that this question was never really answered based on the OP's question. The answer depends on a lot of factors, and where in the country you are located. Here in Southwest Florida we have people that want to swim essentially year-round except for the coldest few weeks of the year. That means we shoot for a system that can heat pool water 10-12 degrees Fahrenheit above an unheated pool. To do that most commercial panels will need from 80-120% of the pool surface area depending on the panel and orientation. Some panels do better when you need the heat the most (in the winter months). Separated tube type panels lose more heat (or absorb less heat more accurately) in cool and windy conditions. They work best when the ambient temperature is hot (when you need heating the least). Panels oriented to the south or southwest are best.
It is a really location specific thing. You may live in Canada and swim 2 months a year and get 10 degrees of temperature rise with a solar pool heater, but that's because the ambient temperature is warm anyway and a wider variety of panel types may work. Where you want 11-12 months of swimming, orientation and panel selection may become more important.
I'm afraid there is no easy general answer without knowing where and when you want to heat your pool, and a local solar pool heating professional would be your best source to discuss your needs and realistic performance expectations.
It's also important to note that a pool cover will help retain heat overnight, and you will achieve higher overall temperatures. It's not uncommon here to get temperatures 15-17 degrees higher than an unheated pool with a properly sized system and diligent use of a cover. Uncovered pools will lose heat overnight and will take time to recover each day. The amount of heat lost is mostly a function of surface loss and the ambient air conditions above the pool surface.Comment
