I'm about to install a solar pool heater on my house in Mexico. Eight 10' X4' panels, about 35' above the ground.
I'll only use the system for a few weeks in the winter/spring, so am intending to use a variable speed pump.
This will enable much lower cost pumping than my current 2.5kw pump, because , for the vast majority of the time, it'll be running at low speed, saving money (@40c/kwhr it is not cheap there)
My problem is pump selection. I need something that will have sufficient power to overcome the very significant static and dynamic head. I'm thinking about a Pentair Intelliflo VS or a Hayward SP3400VSP.
I believe that, once primed, I can still reduce the speed to give me the necessary flow rate of approximately 32 GPM (4GPM per panel), which will still be cheaper (per hour) than my current pump (although running more hours). It'll be more expensive when it is running (for a limited number of weeks), but, overall, it'll be cheaper, with less stress on the system and, hopefully, a cleaner pool. (By the way, if I look at the pump curves, I can see the speed required for a particular head. Once the pump is primed and water is flowing, does the downward flowing water compensate for the upward static head and reduce the speed required?
Does anyone have an opinion if this is a good idea? Would a booster pump be better? Would a two speed pump be better? I am tempted toward a variable speed pump because I do not know the details of the plumbing and panels, and, therefore, cannot know exactly what fixed speed pumps will work, nor have the flexibility to adjust and control like I can with variable speed pumps.
Also, I read that the Intellflo VF doesn't work with solar systems because its automatic priming system shuts off before it can lift the water to the roof. Can anyone confirm that variable speed systems don't have this problem?
Final questions are related to drainage and the effects of a vacuum relief valve. What is the best way to drain? I have read some stuff about "specialized" three port valves which auto drain. Also, wonder what the exact plumbing method is, especially the need for isolation valves. Any help gratefully appreciated.
