I keep day dreaming and sketching and thinking and...
When the garage was built it was a standard 2 car with an added 10 ft to the back. I've made some improvements, insulation etc. My shop is now a 10x25x8 box. What I'm missing in my calculations is what to expect from a hot air panel. I have a propane heater 30/40/50k, and a 1500W heater. The shop was 70 deg at 7 PM last night and is now 40 at 9 AM with an outside temp of 10 deg. I left the 1500W heater running. I'm thinking if I went to 2500/3000W the temp might hold. I say the above so you get the feeling for size (250sf) and insulation factor.
My question is: One square foot of a pop can panel will deliver ??? BTU on a average. So if I need 10K BTU and 1 sf will/would put out say 300 a 4x8 panel would work. But if only 150 BTU per foot then I'd need 2 4x8 panels. 75 would require 4 panels.
Thanks
Thanks
