Well I said I would post some pics of my new solar heater so here you go. Along with a little explaination of what I was thinking. I wanted to think outside the box like I usually do, so that is litteraly what I did. I made a soda can solar heater without the insulated box. All I needed to do was place it inside the window instead of outside. Now some people would say just let the Sun shine in, which it does anyways, this doesn't block that much, but the Sun usually just shines in and warms the kids toys (this porch is used as a play are for my kids) and I don't think the toys are very efficient at converting the Sunlight to warm air. My solar heater sits on the window sill and blows out warm air converting the Sunlight efficiently to heat energy.
All it is made of is 5 coffee cans with holes in the top and bottom, with 3 soda cans inside each, attached one on top of the other, painted black, with a computer fan powered by a solar panel. Thats it.
It's simple, with no tubes going in through a window to seal up, no insulating a big box, no glass, nothing to buy because it's all reused materials.
This thing cranks out 90F+ air while the room is 60-70F, not bad. I'm using a larger Solar panel than it needs because I'm going to build another heater and I'm going to run them both from the one homemade 30 watt panel. One of my smaller panels wasn't pushing the fan as hard as I wanted it to either.
This is used in a porch that is used as the kids extra play room. It is basicaly a three season room and unfortunetly it is our only south facing room. I have insulated it and we are now able to use it most of the winter on sunny days, so I am just trying to make it a little warmer without paying to heat it.
Let me know what you think, any ideas are welcome.
Green
solar penis 001 (600x800).jpgsolar penis 003 (2) (800x600).jpgsolar penis 004 (800x600).jpgsolar penis 006 (800x600).jpg
Green
