Air Conditioner repairing service
  • JamesVorn
    • Oct 2015
    • 4
    We are professionals of repairing air condition of your house or car. if there is any problem you face in your air condition then contact with us. Our professionals will help you to solve all your problems.
    --Mod Note: This post is marginally off topic for this discussion area and is more than marginally advertising, which is not allowed without a contract (check with Solar Pete for rates).
    Only the fact that there are no links, phone numbers or email addresses in the post is keeping it from being summarily deleted along with a ban on your userid. That and the fact that Mike actually had a question for you.
    wife's 22 yr old car needs recharge, I have cans of DIY r-12, but my hose for it is rotten out, do you have any solution ?
      My late mother's 1972 Mercedes needed all of its A/C hoses replaced back in 2004, but the cost would have been more than the Blue Book value of the car.
        • 15159
        But it was a classic 1972 Mercedes.
          Yes. Unfortunately is was also the first year Mercedes had to meet US emissions requirements. They only qualified one engine configuration, the one designed for the next larger model, and shoehorned it in under the hood. In addition is was only marginally driveable with the factory tuning. Even with a 4 speed automatic it would stall a lot at stop lights.
          It is currently sitting in our back garage waiting for a new carb. (Have not been able to find one in eight years of on and off searching.)
            • 5209
            You can just buy some hose. Use the newer Barrier AC Hoses which won't pass so much gas. Just
            cut those crimps off the old hoses, slide the new on using some of that refrigerant equivalent of
            pipe joint compound, and apply a couple refrigerant screw clamps. Did quite a bit of that when
            A/C was being retrofitted to cars. Bruce Roe
              Refrigerant screw clamps have more leverage to allow higher clamping force?
                • 5209
                I believe the difference is, the surface gripping the hose is more of a perfect circle than
                more generic clamps. Important at 200 psi. Some have a spacer indicator tab. Bruce Roe
                  • 15159
                  Originally posted by RickDavis16
                  Air Conditioner repairing great instructions for repairing the electrical electrically powered yourself. It’s key to realize the right technique to do it so that you can break safe.
                  Hello RickDavis16 and welcome to Solar Panel Talk.
                  I am not sure if it is your limited knowledge of the English language which might explain your "hard to understand" post or you are just posting for the sake of getting into this Forum. You might be better off posting in the New Member section along with giving us some information about yourself and why you are interested in Solar Technology.
                  • cebury
                    • 646
                    Suneagle, Isnt that a bot?
                      • 15159
                      It is possible but RickDavis16 is not from the US which could explain the language barrier.
                      • cebury
                        cebury commented
                        Editing a comment
                        Ahh, I see. You are being polite JIC.
                      • 5209
                      You could just convert it to fuel injection. Probably could run the best ever. There will never be German iron here again. Bruce Roe
                      • FrancisHan
                        • May 2016
                        If you live in Morris County then you can consult HVAC company Morris county NJ or if not then any other local professional firm will help.
                        • azdave
                          • Oct 2014
                          • 788
                          I've used hydrocarbon refrigerants in my old R12 A/C vehicles for close to 15 years. No hose or compressor oil changes required. Great for the DIY crowd.
                          Used in my 91 Aerostar, 87 B2000 and 1965 Corvair with great results through the hot summers in the Phoenix desert. Search ES-12a or Envirosafe.
                          Dave W. Gilbert AZ
                          6.63kW grid-tie owner
