Good afternoon. I'd like a little advice please. I have referenced these and other forums many times to build what I would consider to be a very successful solar air heater panel. I've been lurking, reading and gathering information for some time.
The panel is 36x80 with single panel glass, two layers of black aluminum screen in an insulated box. I live in SC where it has been fairly cold recently. The panel has been running for one month. It noticeably warms the living room and kitchen (400sqft) which were previously the coldest rooms in the house. I built my own fan controller using Arduino which posts updates on the internet for me to watch from work during it's operation. Yea, I am proud of the controller
I calculate the panel makes about 850btu/hr of heat on an average day, ranging from 0btu on a cloudy day to near 1000btu/hr on a ~70degree say with full sun. I used a 13gal bag to estimate the airflow.
I installed the panel in the one location on the entire house that was reasonably accessible, would permit a temporary mount (since this is a prototype) and could be piped into a window to avoid drilling 5in holes through brick walls. Since the panel works so well I acquired three more panes of glass to build more panels and wish to permanently mount and duct them.
The trouble is, I have no south facing walls of roof. The house is near 45degrees off of south which makes mounting very difficult. I pretty much have to install the panels on the roof due to the layout, roof, trees, shadows etc. A south facing panel means it needs to be mounted off the roof on stilts which stinks.
Do y'all have any thoughts? Any links to people that have had the same problem with a solution? I can't find a solution I'm especially fond of.
Thank you.
Thank you.
