Bulbs,, LED or SMD bulbs for in the home?
T-5 is the latest and greatest - most efficient. Most lighting in my home is now T-5.Leave a comment:
T-8, T-10, T-12 are medium bi-pin, smaller to larger tube diameters
Yes, T-5s come in 12 voltLeave a comment:
Any RV or Marine Toy Store has them.Leave a comment:
Ok yes I have seen fluorescent lights before. Just never heard them called t-5 before.
I thought that that might be some type of 12 volt light. As I said in my post I'm using 12 volt
fixtures. Do these come in a 12 volt?Leave a comment:
There are LED lamps that do a pretty good job. Their output is about 80 lumens per watt and they look just like the T5 lamp in size and shape. They do put out enough light for me. The difference is that they run off of 120 volts and don't need any ballast to work.
I currently have (3) four foot LED lamps at 18 watts each and (5) two foot LED lamps at about 10 watts each. I used the exact same fluorescent fixtures that were already mounted in my closets, laundry room and garage. I just rewired them to power the LED lamps at 120 volts. While the lamps were more expensive than a T5 they are low wattage and have a 50,000 hour life (which may be exaggerated) but I saved the cost of not having to purchase new fixtures to house the T5 lamps so I think I am ahead at this point. Time will tell if I made a good or bad investmentLeave a comment:
You have never seen Fluorescent lighting before? LEd efficiency runs from 30 to 80 Lumens per watt. T5 runs 96 to 105 Lumens per watt.
Ok so how do the SMT - SMDs compare to T5 fluorescent?
And where can I get a look at a picture of one of these T5s? <--I'm not sure what that isLeave a comment:
Now with all that said, LED's are not very efficient compared to say T5 Fluorescent lighting.Leave a comment:
HUMMMMMMMMMM I have been on this forum less than 24 hours and I have already learned
something. Looks like I'm off to a good start.Leave a comment:
Everybody's look comparable, since SMT stands for Surface Mount Technology and SMD stands for Surface Mount Device.
When used in combination with the designation LED, they are interchangeable terms. The LEDs that were produced earlier are plastic-encapsulated LEDs, and they have a much lower maximum power output per device because of the poor heat sink properties of the leads and the plastic package.Leave a comment:
Your SMD's look like my SMT's !
The difference is SMT leds are leadless die, soldered to a PCB, and the other bulb, is made from discrete packaged LED's. Properly set up, SMT die can handle a lot more power, the discrete LED's are only good for about 1/4 watt, if you want any long life from them.Leave a comment:
Hi,
I'm just getting into solar panels. But I have been using 12 volt lights for a while now and I have been
using 1156 automotive tail light bulbs. I'm looking for something more efficient.
I have ordered a two different types of bulbs but I'm still looking for some input on this.
what I have coming are 2 LEDs and 2 SMDs just sort of see for my self what they are like.
Is there anything better that is usually used in indoor lighting?
this what I'm trying. LEDs
Or SMDs
