I plan to install a few 12v led lights on a short rock wall next to some rock steps, hidden and to shine down on the steps. With a dusk to dawn switch or a timer. I found some auto license plate lights, 12v (9-14.8), .5W, 35 mA draw. I want to install 2, maybe 3 of these. The landscape wires would be about 10 feet long, 16 awg. I bought a cheap charge controller that has a dusk/dawn switch on it, I think it is 7A. The only instructions I have is what wires go where. It has a charge light and load light. I think it cuts the load off at 11somethingV and the charge at 14somethingV. I hooked it all up with a new 12V, 5A battery. It worked for about 6 hours and went off (I also had a strip LED hooked up at the same time)1W, 130mA). I'm not sure if the CC has a timer or the voltage drained bellow the load cut off. I tested the battery with an analogue tester, it needs charged, was about 12.0 V but not sure how accurate the tester is.. I still have to get a solar panel and see if it all will work together.
if the lights are .5W each, is that .5W per hour? as in 2 lights X .5WH X hours on per day (night). if on 12 hours per day (night) it would be 12wh/d ? and if that is right, then it would draw 1 amp per day? 12WH/12V=1A? And if that is correct, that would be 20% of my 5A battery plus what the CC and wire draws? And if all that is correct, what size PV should I have? not much sun here in SW ohio and sort of in the woods, maybe get 3-4 hrs of direct sun on a PV on a good day. Also, should I have fuses anywhere?
