Hey everyone, I'm new here and new at solar so bare with my vocabulary.
. My setup goes as follows.
1. Sunforce 50022 5-Watt Solar Battery Trickle Charger
2. Power Bright PW400-12 Power Inverter 400 Watt 12 Volt DC To 110 Volt AC
3. 12V 22Ah Replacement for APC SU3000RM SU3000RMNET UPS Battery - UB12220
4. Trinity Lighting Post Light Sensor Model #: 6780-02B
Ok, so this has been a summer project basically working on it when I can. I bought this stuff and hooked it all up in August. I just now got around to getting my post lights and connected everything together today. Ok so in August, solar panel mounted, wires to battery. From battery pos and neg to input of inverter. Battery came with some charge so I tested it soon after with my cell phone charger and it worked. So it has sit like that since August hooked up. So today I hook up my lights and I get everything wired up, turn my inverter on, and put my finger over photo sensor so lights would come on and blah...nothing. Got my volt meter out and the battery read .5 volt. Disconnected solar panel and checked it and it was putting out 19.5V. While panel unhooked checked battery again and it read .2V. Hooked panel back up and checked battery again... its .5V. So, then I unhooked pos wire from inverter and checked battery again, it read .6V and was climbing. Within a matter of minutes, I had almost 3V. Connected positive wire back to inverter and immediately checked battery, it was back at .5V. Disconnected again, and battery read 3V and climbing. So, my inverter is preventing my battery from charging??!! Is it backfeeding or ......?? I'm so confused. All the reading and research I done before I even started told me anything less than 15 watts, I don't need a charge controller. This panel is a 5 watt trickle charger. Maybe the inverter is junk...?!? Any advice or help would be greatly appreciated, Thank You.
