Led vs CFL
Taken care of for nowNABCEP certified Technical Sales Professional
No trees were harmed in the creation of this message. But billions of electrons were terribly inconvenienced!Comment
You may not be a spammer however someone dropping a link on their first post is suspicious.
Try them let us know how they work write a review without links.NABCEP certified Technical Sales Professional
smokemaker mabe you were jumped on a bit hard. But you have to see it from how the "oldtimers" on here see it. If you post a link on a first or second post telling about something amazing the first thing that jumps into our heads is"SPAMMER"" mabe your genuine and have something interesting to tell. Dont give up just get one of the products you think is useful and in some way connected to solar or electricity saving and THEN post results with the link. That way we will have more faith in your post.. OK??Comment
Eloquently said.smokemaker mabe you were jumped on a bit hard. But you have to see it from how the "oldtimers" on here see it. If you post a link on a first or second post telling about something amazing the first thing that jumps into our heads is"SPAMMER"" mabe your genuine and have something interesting to tell. Dont give up just get one of the products you think is useful and in some way connected to solar or electricity saving and THEN post results with the link. That way we will have more faith in your post.. OK??
Thanks John!NABCEP certified Technical Sales Professional
I have the same problems
I also am facing the same problems and don't know why. Hope some one can tell me how to fix the problems.
Thank you, guys
Mod note - free advertising is not allowed.Comment
Hey there Sunking, I just signed up here to get some information about LED diode brands, I have been studying trying to make a good LED product, and I have seen test reports on lights with power usage and lumen output, I never saw these numbers that you claim. I don't know if I misunderstood you, but these calculations are done not on the chips but on the entire product light with diodes and driver, for example 7x1w diode inside a PC milky cover and driver consumes total of 8.1W and gives 555.7Lumens with 100-110Lm/w chipWell now you have uncovered a dirty secret. LED efficiency is not what they claim. When they rate them they do so with a brief pulse, at room temps, and in the middle of the focused beam. They do not count the power being used you feel as heat.
Example they may rate a LED @ 100 L/watts for a 1 watt LED, but it burns 3 watts of power with ballast.. That makes it a real 33 L/watt or about the same as a plain old fashioned Edison incandescent bulb.Comment
