400W HPS Equivalent
Lots of companies are talking about equivalents with LEDs these days. Because there is really no standard that the industry observes I've seen some pretty unrealistic claims. As a rule of thumb for a street light, you can use about half the energy with LED versus HPS to get to the same minimum foot candles (light on the ground). So strictly speaking you would need a 175W - 200W LED. This is huge load for solar.
Because good LEDs use optics that spread the light effectively, you can also mount the lights at a lower height so that you lose less light reaching the ground. You get less contrast, puddles of light, and that will improve visual acuity as well. If you have really good optics in the fixture.
High color temperature LEDs (cool white versus warm light) also offer a much whiter light than HPS, improving visibility with less light. Because of this, you might consider using a lower light level overall. For example: if your light currently is lit to a 1FC average with a minimum of .2FC, try lighting the whole lot at minimum .5FC average.
You don't have to figure it all out yourself. Reputable solar lighting companies can provide recommendations based on the Illuminating Engineers Society (IES) and help you to design an effective layout.
