Laugh - like so many solar projects, where is he NOW? That project was built and documented over 1.5 years ago. Many online projects are like this - cobbled together enough to work to make the initial documentation / video. Then nothing about all of it thrown into the corner of the garage.
First, he killed his first battery with no controller for an undersized panel - which WILL kill a battery eventually. And no blocking diode it seems. No mention of solar insolation hours. I do note that this project was documented in the SUMMER as well. Not a solar engineer, even amateur. Just throwing stuff against the wall.
The point is, you are grossly underpowered for your load for *real world* conditions. Also consider that the battery you are using is a small agm, and at 7.5ah is usually one designed for a ups, not repetitive cycling. Add to that retail storage factors without charge and a whole host of other factors to make that battery pretty sad once it reaches your doorstep.
Try again - get a common 18ah agm, (which will help limit your DOD, and 40 - 60 watts of panel. You'll be much happier. Put a battery charger on it before starting out. Don't use a crappy ping-pong type of controller. Go with a simple Morningstar, Steca, Xantrex, or the like.
