Cold weather battery option for shed?
  • CruisnGrrl
    • Sep 2015
    • 15
    We have an 8x6 shed where we keep the recycling, garbage, snowblower and other stuff. Winter time it gets below freezing (right down to -20c which I understand is not good for nimh batteries, nor lead acid (which explains why a lot of my garden lights only last a year). Apparently nicd are better but they have memory problems. What rechargeable systems are out there that can hold up to the winter temps?
    I looked at the "shed light" that harbor freight sells but I suspect the batteries would only be good until winter.
    • 5208
    Lead acid will function at -30F (-35C) if fully charged. Started my car. Bruce Roe
    • lkruper
      • 892
      As Bruce said, conventional lead acid batteries can go quite low when fully charged without freezing. AGMs are even better. However, you should also be aware that the colder temperatures decrease the capacity of batteries significantly (while extending their lifetime, which is a good thing).
        Fully charge them and you are good to go.
        • CruisnGrrl
          • Sep 2015
          • 15
          Good to know. I have a couple of these http://www.canadiantire.ca/en/pdp/co...-0112007p.html and some motorcycle batteries kicking around, now i just need the appropriate lights and a switch.
