solar LED lighting for garden
  • flysky
    • 4
    I am a huge fan of solar lights and LED bulbs, because I think they are more economic and are safer for the environment. I bought 2 solar LED lights for my garden.
    Could anyone tell me how long does the light last for on a day's charge? http://www.amazon.co.uk/dp/B00REDZRV8
  • paul65k
    • 116
    I have those very lights (4 of them) installed outside on my back porch and they only receive direct sunlight about 3 - 3.5 hours a day based on the way they are oriented..........in my case the lights seem to stay on (low mode) for at least 7-8 hours and fall off quickly maybe only a couple of hours if you walk past it often.
    I would buy them again
    • flysky
      • 4
      The shell of this is made from stainless steel, Is it the same yours?
      • paul65k
        • 116
        Yes they are....they've been installed for over a year now with temps into the 120's at times during the summer and they are still working great....the only weak point on them is the little opaque lens over the motion sensor that does give up after about a year outside and crumble after the slightest contact.....2 of 4 have gone but the units are still working fine even with them gone.
        • flysky
          • 4
          OK, thank you so much paul65k. I will try it. I think it would be an excellent job and is an attractive security feature to add to the house!
          • PNjunction
            • Jul 2012
            • 2179
            Careful there. One has to consider the total-life-cycle when thinking about economy and being safer for the environment.
            How much petrol did it take to ship these from China to the distributor via land and sea? How efficient is the manufacturing facility? In some case, just the manufacturing and distribution of low-end stuff like this can far outweigh the "green" that the end-user saves the planet.
            I don't see any ability for the end-user to change batteries. Is the cell a NiCad, which is pretty toxic, or have they gone to something better like a Nimh, or better yet, LiFePo4 lithium? Or do you just throw this device into the landfill when it doesn't work?
            Just be careful about "green" advertising and products. Much of it is short-term and is really just targeting a feel-good marketing demographic.
            • paul65k
              • 116
              Originally posted by PNjunction
              Careful there. One has to consider the total-life-cycle when thinking about economy and being safer for the environment.How much petrol did it take to ship these from China to the distributor via land and sea? How efficient is the manufacturing facility? In some case, just the manufacturing and distribution of low-end stuff like this can far outweigh the "green" that the end-user saves the planet.I don't see any ability for the end-user to change batteries. Is the cell a NiCad, which is pretty toxic, or have they gone to something better like a Nimh, or better yet, LiFePo4 lithium? Or do you just throw this device into the landfill when it doesn't work?Just be careful about "green" advertising and products. Much of it is short-term and is really just targeting a feel-good marketing demographic.
              The version of these lights I have utilize AA rechargable/replaceable batteries. I always recycle responsibly but I can't say for sure that the waste company here in town will not just dump them in a landfill
              • PNjunction
                • Jul 2012
                • 2179
                Ok, thats a lot better. My suggestion with these lights is to use AA "low-self-discharge" nimh batteries. You may also see them sometimes as "pre-charged". Sanyo / Panasonic Eneloop are the gold standard among us AA nerds.
                The "loop" in eneloop was back when they first started, their whole mantra was about improving the entire life cycle considerations, and when they did the 70% pre-charge, that was done via solar. Not sure if Panasonic still does that today though.
                Either way, avoid the "standard" AA rechargeables as their internal resistance and self-discharge are enough to waste what little power gets delivered to the cells during less than perfect conditions. Eneloops, and their other "LSD" cousins will charge faster, retain that charge longer, and is an all around better choice for this application mostly due to really low internal resistance.
                • ferice
                  • Sep 2015
                  I also want to buy this solar light for my beautiful garden. But I'm a housewife, have less knowledge about it. Most solar lights are plastic, I want to know the durability of this stainless steel solar light, and how long does the light last in winter?
                  • moseall
                    • Sep 2015
                    I am trying this in the summer so cannot comment on its winter performance. It charges in a few hours and lasts for about three days.
                    • ferice
                      • Sep 2015
                      What's the range of this solar light?
                      • moseall
                        • Sep 2015
                        The range is up to 5m.
                        • Guest
                          Am sure they would look amazing. It is more attractive and good looking than plastic bodied solar light.
                          • paul65k
                            • 116
                            Looking back at this link...........I have to update and say that the little plastic cover over the motion sensor has now deteriorated and is cracking on all of my lights.....they still seem to be functioning but I'm guessing that over time this could/will be an issue???
                            • azdave
                              • Oct 2014
                              • 785
                              Similar problem with my expensive metal solar LED path lights. You would think a solar powered outdoor light would be constructed of UV resistant materials. Not always so.
                              In my case I recognized the problem before the warranty was up. I had all 36 of them replaced by Brinkman with brand new units but this time I applied a UV resistant film over the trouble area. I used the same "rock chip" shield film like they apply to new cars. I bought a small roll on eBay. Over a year now in the Arizona sun and no signs of problem returning. Maybe that would work over your motion sensor eyes before they get any worse?
                              Dave W. Gilbert AZ
                              6.63kW grid-tie owner
