I'm slowly making the move from CFL to LED with solar, and things are improving from when I tried a few years ago.
Part of my hobbies are high-frequency shortwave listening, along with vhf-uhf scanning. When I tried LED's a few years ago, the drivers in the bulbs tended to spew garbage all over the spectrum, but usually not both at the same time. This limited my choices greatly, so I went back to CFL's that were quality enough not to spew so much junk.
I'm pleased to find that the Osram / Sylvania Ultra LED 40w incandescent equivalent (6.5w in use) is well-behaved across the spectrum that I monitor. UNLESS of course you put your radio or other device within a foot or two.
I also want to be able to run from solar / battery backup with an inverter. And, like my cfl's, I don't really want to dedicate a pure-sine-wave inverter to this task, although obviously I can. Instead, I'm running backup lighting solely from msw inverters, and putting the Sylvania led's to the test. We'll see as it has only been two hours now. But no immediate poof! I'm trying to beat it into submission running it in the garage at about 97F too.
I used an infrared pointing thermometer and did notice about a 5 degree increase in temperature at the driver base, as compared to running it off pure ac from the poco.
Some interesting power measurements:
With the same setup and same msw inverters, I measured the amperage drawn from a big 12v agm to compare against my CFL's. Power factor in both cases is obviously in play here. These are the results for the "40 watt equivalent" CFL's vs the Sylvania Ultra LED. Power drawn also takes into account the inverter's load as well.
CFL - 14 watt / 40w equiv
1.95A drawn from the battery
Sylvania LED
6.5 watt / 40w equiv
1.35A drawn
So while I have nearly the same luminence with the bulbs, I am saving a considerable amount of power with the led. BUT in my case, if that meant spewing out a lot of noise in the spectrum, that would have been the end of that like when I tried some others years ago. And the color temp and so forth are pleasing enough to me to not make me feel like I'm camping out with cheap led's inside my house.
What I also learned then was that you can't just count on a brand to behave the same way all across the board either. So for right now, this model is working well for me.
I'll let you know if the MSW type inverter makes the Sylvania led groan.
Sylvania LED
1.35A drawn
