I have a low voltage lighting system around the outside of my house. It started with 20 Watt halogen bulbs but those have been replaced with 3Watt LED bulbs. I have the following transformers running the lights: 1 300 Watt, 1 200 Watt, 1 120 Watt and 1 45 Watt. The 45 Watt runs some sidewalk lights that are on from Dusk to Dawn and all of the others are set to be on for 4 to 5 hours after sundown depending on the season. What I would like to do is set these lights up to a solar charging system. I think it would be easier to just have everything run off of one dusk to dawn photocell and remove the transformers all together. To me it sounds silly to collect enough electricity to power the transformers that are really bringing everything down to the same voltage as the lights.
According to my calculations I am going to need 80 watts of power per hour which is 0.080 Kilowatt hour. Figure 15 hours of light is desired (trying to figure high just in case), then I will need 1.2 Kilowatt hour capability. Now that's figuring that I can remove the transformers all together and run these 12 volt LED bulbs off of a series of 12 volt batteries for 15 hours. Figuring I would have approximately 8 to 9 hours of available charge time, I would need a 200 watt solar panel to charge the batteries to the needed 1.6 Kilowatt capacity.
If I have lost you already then it should be obvious, I am still learning but at this point this is still making some sense in my head.
What I haven't figured out yet is how many batteries would I need to provide this kind of electricity. If I am way out in left field please help straighten me out, but if I am right and someone has the time to point me in the right direction I would greatly appreciate it.
Kurt
Kurt
