This is where you are getting lost. You are not specifying Charge Controller Type or battery voltage.
With PWM Input Current = Output Current. If you were to use 4 of those those panels in parallel on a 12 volt battery would deliver a max charge current of 4 x 4.86 amps = 19.44 amps or just 19.44 amps x 12 volts = 233 watt out of 680 watt input.
With MPPT Output Current = Panel Wattage / Battery Voltage. So if you used those same 4 panels on a 12 volt battery (makes no difference if they are series or parallel) will deliver [4 x 170 watts] / 12 volts = 56 amps.
Is 56 = 19.44 ?
You had better know what you are doing.
Is 56 = 19.44 ?
