I live in Palm Springs, CA where the temperature 4 months of the year is in the 100s, sometimes in the 110s. One solar installer wants to sell me DC Solar panels (Canadian Solar), and the other wants to sell me AC Solar panels (SunPower). I have done my research and have a good understanding of the difference between the two. My question: Would one type have preference over the other type under the extreme heat we experience here in the desert? Which panel, the AC or the DC, is likely to give me the least trouble here in the desert?
AC or DC Solar Panels in Extreme Heat?
panel performance is going to be about the same.
A dc Panel with the inverter in a nice cool place might perform a bit better.
Ask the SP dealer about using a string inverter and mounting inside. SP panels have a very good temperature coefficient.NABCEP certified Technical Sales Professional
The industry has started to call modules with the micro inverters attached like Sunpower and Westinghouse AC panels. This probably started with gosolarcalifornia dot org calling them that.
As Callifornia goes so goes the country.
I know I know........................NABCEP certified Technical Sales Professional
The SunPower dealer does propose mounting a string inverter inside the garage, which, although not in the direct sun, still gets quite hot in the summer. Everything I've read about the SP panels tells me that they are the "cadillac" of DC solar panels. I posed the question because I am concerned about the performance of AC solar panels, each with its own micro-inverter, in extreme heat year after year after year. Common sense tells me that the DC system with the inverter in the garage is going to survive better in the hot sun, but I don't really know. I'm unable to find any field data to either support or refute that belief . . . perhaps because the AC systems are so new.Comment
I believe you will find that solar panels with built in micro-inverters are called AC solar panels as a simple way of distinguishing them from DC solar panels, at least by some manufacturers, as well as others. See http://us.sunpowercorp.com/homes/products-services.[SIGPIC][/SIGPIC]Comment
Might make sense to you but it is meaningless - by that definition any panel using a micro inverter would be an AC panel[SIGPIC][/SIGPIC]Comment
Originally posted by jzchenI know there is a concern about DC over long wire runs. That is why we use AC from the electric company. It can travel long wires without much degradation in power. The question is what is considered a long run for DC. Actually DC is preferred for high voltages and long distance transmission
There is also a safety concern over the voltage created by stringing the panels in series. This creates a very high voltage. The claim is that using a microinverter makes the wiring safer, ie. less likely to arc fault.The moon or a star may fall on your house tonight as well - those concerns you mention are not really concerns - except possibly to a salesman who has a few trick words and no knowledge.
One last thing is that if one panel goes down for whatever reason, then the others, (at least on that string,) only work at that capacity. If it completely shuts off, so do the others. It is harder to diagnose which panel went bad.. You heard that from a solar pro like Naptown or KRenn or others here? Not a big deal.
Downsides to "AC panels," or panels with microinverters, is that you have a whole bunch of inverters that can go bad, as opposed to one, although they there is one enphase inverter warranted for 25 yrs I would suggest you talk to solar companies and relay their points back here. When you are told you have found one that is not blowing smoke at you the guys will let you know.
Another suggestion would to be to stay totally away from green sites in regards to RE. They contain about 99.99% wrong information with youtube being even worse.[SIGPIC][/SIGPIC]Comment
However in solar power systems you generally have three choices:
Low voltage DC (i.e. 24, 48 volts)
Medium voltage AC (240 volts)
High voltage DC (300-500 volts)
High voltage DC is much better than low voltage DC or medium voltage AC. Wires can be smaller and losses lower.
There is also a safety concern over the voltage created by stringing the panels in series. This creates a very high voltage. The claim is that using a microinverter makes the wiring safer, ie. less likely to arc fault.Comment
My home is wired 230/408 3 phase - Outside of the US 240 is very common. Only the heat pump is on the 408 I believe.[SIGPIC][/SIGPIC]Comment
The risk, of course, is that people will misinterpret the terminology and think that there is something different about the PV cells themselves.
(Rotating at 3600 RPM so that the light hits them alternately on opposite sides?)
SunnyBoy 3000 US, 18 BP Solar 175B panels.Comment
The vendors starting the new name are playing a game where they hope to get extra sales from people that don't understand they have the same product to sell as the next guy - not nice but normal.
I think the RPM's would have to reach somewhere in the 100,000 range to really get into the sweet spot[SIGPIC][/SIGPIC]Comment
Originally posted by jzchenIt was my understanding from EE class why AC is used instead of DC over long wires. Sorry if I was misinformed.
So for a long time the ability to boost and drop voltage made AC the winner for long range transmission.
Now that we can boost and drop DC voltage, it wins for a different reason. To transmit an average of 1000 amps in an AC system you have to transmit a peak of 1400 amps, and to transmit an average of 12,000 volts you have to have peak voltages of 16,000 volts. However, to transmit 1000 amp/12,000 volts DC you need to handle only 1000 amps/12,000 volts. That means that towers have to be higher, wire spacing has to be greater and conductors have to be thicker to handle that power level at AC.
Since I am considering a centralized inverter system, I am considering the consequences down the road when I might personally try to change the inverter to save money. (I guess I don't want to accidentally fry myself.) It would be worse though if I had to get on the roof and change a microinverter as I'm not good with heights, and a pain to remove a panel to get at it....Comment
