I am considering a solar PV system to tie to the grid. I'd also like to be able to run a well pump when the grid goes down. Our well pump is 25 years old, so a replacement pump is not out of the question. I'm not sure how long we should wait before replacing a well pump.
Typically, we lose power for a few hours, up to a day or two. In general that is not a problem, other than we have no water for toilets, brushing teeth etc. We usually are aware of the possible loss of power and fill the bathtub to have a supply of water for flushing. And there is some water in the pressure tank. During the past few years, we have had a couple of instances where we were without power for 4 to 6 days. We have a shelter, a wood stove for heat, hurricane lamps for light, but no source of water. I have not given in to buying a generator yet. I really don't want another internal combustion engine to maintain, just to use once or twice a year.
If we do install a solar PV system, it just seems logical to use that power during outages. Even if it is just to refill the pressure tank once per day. I'm aware of the turn on current problems of the well pump, although I haven't figured out what my pump's current would be. I've done some research on pumps with soft start, such as the Grundfos SmartFlo. If these would work and my current pump is an issue, I would consider replacing my 25 year old well pump to have water during outages.
I'm posting to draw on the experience of this forum. I've been lurking here for awhile now. Trying to get informed, but I feel like I'm spinning my wheels. I do have an installer coming next week to discuss whether the site is suitable for solar. I would have to remove some trees for sure. I hope the installer can give me some guidance.
Is what I'm thinking of reasonable?
Would the backup add a large extra cost to the system?
Should I be spending more time investigating a new well pump?
Some info on the well pump and water system.
* Pump: Goulds 10EJ05412 1/2 HP 230V 1PH. Well is 275 feet deep.
* Franklin Electric Submersible Motor Controller
Model 2801054910. S.F 1.6 S.F Max Amps = 5.9
* Pressure Tank: Well-X-Trol by Amtrol. WX203
