Hi,
I'm in the process of converting a garage into a workshop and require some power in there, for lighting (using this kit probably.. Solar Power 12v Lighting kit) and for running an air compressor for tools off an inverter (230v AC, in the UK).
I am fairly new to solar systems and electrics in general so was looking for an easy guide on what I need and how to set the system up.
I have a rough idea from the research I've done. I need:
Solar panel (looking at this 60w kit, or is this overkill?)
Charge controller/regulator (above kit comes with 7a regulator)
12v Lead acid battery (looking at this 12v 24Ah one)
Fuse box for protection??
Inverter (will this 600w and 1500w surge be sufficient?)
have no idea on the type of wiring and fuses I will need, although some of the kit comes with wiring already.
Some advice and directions to some good solar guides would be appreciated, thankyou.
The garage won't be used that often, maybe 2-3 times and week, using the lights 2-3 hours in the evenings and the compressor every now and again.
Pete
Pete
