  • Apollos Harness
    • 3
    New to Solar. Help with 3 Line Diagram/ Wiring Diagram
    Hello,
    I am new to solar but I have been working with someone who has been working with solar for years. He has taught me a lot about solar and I am interested in learning more. Recently he has been trying to get me to study 3-line diagrams because he wants me to be able to create them for some of our future jobs. I realize that this will take some time getting used to, and I am in no rush, but I don't think it would be that difficult to get the logistics.
    I have a few questions....
    1. First of all, what would be the best program/software to work on a 3 line diagram. I can buy whatever, but I want whatever program makes it the easiest.
    2. Should every 3 line design be different for each job? Do they correspond with a diagram or map of the house or are they meant to be rough examples of how the solar wiring would be on a house.
    3. Whats the best way to learn the software for creating a 3 line diagram? Should I just play around and see if I could figure it out on my own? Are there any tutorial videos out there teaching you how to create a 3-line diagram?
    Like I said, I am new to solar, but I want to learn as much as I can. I want to be able to help my boss by creating these diagrams and making a little extra cash. I have seen many basic ones that he or someone he knows have created and they are fairly simple. I almost feel like I could recreate it in MS paint, but I know there are easier programs for doing these diagrams.
    I am from Westchester county in New York and below is a design that my boss made that was declined by the Rockland county engineer. What is this diagram missing that he should have put on it? How can I make this design pass inspection?
    If the link doesn't work just copy and paste the url.
    Thanks for any help.
    Brett
    Do you have any background in electrical? Software is the asy part - you need to know what you are doing.
    • Naptown
      • 6880
      OK a couple of things wrong on that drawing
      It appears there are three strings of collectors in the array. This will require a fused combiner.
      Second sizes of conductors are not specified.
      No bonding is indicated.
      No specification on the size or ratings on the buss bars of the panel.
      Input location for the breaker from the inverter is in the wrong position. Should be at opposite end of panel from main utility breaker.sample one line.pdf
      • Apollos Harness
        • 3
        Thanks for the imput. I'll look into fixing those errors on the diagram. My boss is an electrician by profession and I am apprenticing under him to learn all the terminology. I know its not all about the software, and right now I have a basic knowledge of electric as I have only worked 2 jobs with him. I plan to learn as much as I can so that I can help him with these diagrams. He asked me to help him because he knows that I am fairly savvy with computer programs and such. I have plenty of time to learn how to do these diagrams; like I said I am in no rush.
        As for the computer programs go- whats the best one for making 3-line diagrams?
          Originally posted by Naptown
          It appears there are three strings of collectors in the array. [ATTACH]2020[/ATTACH]
          Are we looking at the same diagram as the photo in the post? I see one series string of more than three panels, all with a common protective ground.
          • Naptown
            • 6880
            No what I posted is an example.
            What the AHJ's seem to look for are
            String voltage calculations.
            Max amperage on wires from combiner to inverter.
            Wire sizes per NEC
            Bonding
            In the post Quoted, are you referring to the drawing in the attachment? My attachment is an example not the corrected one for the OP.
            And while we are on the subject these are called one line drawings not 3 line drawings.
              Wire sizes per NEC
              Bonding
              When I look at the original post, I see a text reference to a "three line drawing" and directly under it is what appears to be an illustration from a manual. The only link I can find in the post is the one to your example one line drawing with tables and all the good stuff. Interestingly, the way I found that was by trying to copy the URL associated with the illustration! Either somebody has edited the original poster's link out of the message, or I just can't find it.
              Strange, isn't it?
              • Apollos Harness
                • 3
                "It appears there are three strings of collectors in the array. This will require a fused combiner."
                My boss said that a combiner is not necessary because the voltage wasn't that high.
                He did say that the rest of the information was good to know. So thanks.
                I still haven't got the answer as to what is the best computer software to make these diagrams.
                Once again, thanks for all the help.
                  Fuses are not for voltage, they control (stop) excess amps. 2 strings need no fuse, 3 need it, 1 device on each string. 2 strings can fry a damaged 3rd string.
                  Tell your boss to get over it, and learn.
                  Or get rejected again.
                    For drawing, I used visio
                    Google sketch is supposed to be ok too
                    • Naptown
                      • 6880
                      My drawings are done in Softplan. Architectural software but I had it, it works OK have to do some work arounds.
                      • JarodGreenTipi
                        • Jun 2012
                        Great community
                        Anyone know of aggregate solar installer liability insurance purchasing opportunities? Electricians only have to pay around $300/yr thanks to their union. Why don't we have something similar?
                        • aymana33
                          • Jun 2012
                          thx
                          thx
                          • hustin
                            • Jul 2012
                            • 25
                            i use autocad. once you get used to it it's pretty easy. plus, editing / tailor fitting for other projects is very easy once a similar diagram is already made.
                              Autocad is very expensive - you might try Draftsight - a free program that is very similar
