I'm trying to determine the size of solar panel system I will need, and to that effect, am trying to determine how SCE's Rate Schedule TOU-D-T will credit my kwh generation during peak times. Under a TOU schedule, my goal would be to create a setup that yields no bill for power usage over a 12 month time frame. Note that this will not necessarily mean that I want to generate as many kwhs as I use. I just need a bill credit from generation to offset usage charges. After reviewing SCE's current TOU schedule, however, I'm a bit puzzled. It is divided into peak and non-peak usage, but within each category, there are different rates for usage up to 130% of baseline and any usage over that amount. Specifically, the total price per kwh appears to be:
I presume that this allows SCE to credit power generated at the .1934 rate for <130% baseline peak power. If so, this seems like a problem, because most of my usage would be in non-peak during which time I would be using significantly more power than I am generating. Thus, most of my usage would likely be charged at the .2390 off-peak rate. Thus, it would seem that the peak power I generate at .1934 per kwh does not even fully offset a non-peak kwh once I've exceeded 130% of baseline. If so, then TOU is much less attractive, and may even be inferior to the standard Schedule D tiered system.
Can anyone using SCE's Rate Schedule TOU-D-T tell me the amount SCE credits you for generating 1 kwh during peak time? Additionally, do you find that on average you are credited more per kwh you generate than you are charged per kwh you use? Thanks in advance.
Peak | non-peak | |
below 130% | .1934 | .1256 |
above 130% | .5234 | .2390 |
