Hi guys. I'm setting up a system in India, where there are frequent all-day power cuts, and lots of sun.
I've hooked up a 500w/24v array to two series batteries via a 20A charge controller. I've also connected a 1400w 24v inverter to the batteries (the domestic kind popular here, that normally charges the battery when the mains is on). The problem is, when the solar array is connected and the controller shows it's charging, after a minute or so the inverter gives a 'low voltage' alarm and shuts off, even though the batteries are fully charged (showing 28v). Disconnect the solar panels and it's fine.
Is it possible the controller pwm or something is messing up the inverter somehow? Are they incompatible?
I've noticed you can get special Solar Hybrid inverters for just this job. Do I really need to replace my standard inverter with one of these?
