As much load as you can shift to daytime, is good. That means you are running directly off sunlight at about 77%, and not recharging batteries, which is only about 50% You get almost 25% more free power load shifting to daytime use.
That's assuming she has batteries to begin with, which isn't indicated in the original question.
Assuming it's a grid tie system, it wouldn't matter WHEN you used the power, UNLESS you have day/night differential rates. If you do have that type rate structure, I'd use as much use in off peak hours, and let the sun run the peak meter back the most.
