  • buercky
    • Oct 2011
    • 5
    solar panel and 1 motor install question
    NOTE NOVICE here
    I am hooking up JUST a 12vdc motor .200ma no load .45ma load to 1 10watt solar panel (.59ma) (18v)nominal and have a question or 3.
    1. do i need a diode to block the voltage/amps created by my the motor from going back to the solar panel for if i spin it manually i see flow. ?
    2. is it best to have a +12V voltage regulator (L7812CV) in series to drop the voltage to the motor since it rated at 12v? because when i measure voltage while motor is running its 11.8v (without regulator) but if i disconnect the motor the voltage jumps up to the nominal 18v.?
    thanks
    No diode needed, unless you are really going to spin that motor up. (and if you have a way to spin it up, why do you need the solar?)
    You don't need a regulator either. You could put a 20W 13V zener diode in to limit max voltage if you want, but the motor will load the panel down pretty good.
    You may have a problem in low light levels, of your motor not starting, and the panel cooking one set of windings, till the motor starts up.
    • buercky
      • Oct 2011
      • 5
      thank you very much for the helpful info.. this all helps.
      I have a thermal switch that wont switch on till it hits a certain temp. So this should help a little BUT any way around the ? panel cooking one set of windings, till the motor starts up
      so your saying on those low light days it will burn up my motor.? crud:O(
      so how do the solar attic fans get around it?
      what about a dc-to dc stepup like this http://www.lightobject.com/DC-to-DC-...ator-P498.aspx
        You should look into a brushless DC motor, with constant auto retry. But to discover deep in the specs, which motors retry, and which give up after 2 tries, is tough. Motor should consume about 60% of PV nameplate, and be able to take a range of voltage.
        • buercky
          • Oct 2011
          • 5
          yea that i have been doing but im on low wattage might you know of sites that have for 10 watt solar .59a only found one so far...
          i also wasnt thinkin on that step up what i need is one that would adjust to a hi or lo which i found out the term is BOOST and BUCK UP and down... I have a little more testing to do on my AMPrage at teh low voltage because if im sure they both will drop when volt drops due to Shade.. but lokig more at teh brushless if i can find some :O)
          thanks again
