  • DtommyD
    • Aug 2011
    New guy- overheating? Troubleshooting odd voltages
    Off the bat I have
    two 10w mono and poly panels (one of each) wired in parallel
    One 7amp charge controller (eBay $30)
    Three 12v 10a SLA scooter batteries (3 years old)
    I have the panels mounted in mostly full sun from 10am to 6pm
    At night I've been running some led lights and the voltage droops to around 12.4 - 12.5 by dawn
    Most days it's back up to full charge (13.4 cutoff) by noon so 2 hours if that.
    Feeling pretty happy about that today I ran some stuff to use up some battery to see if it could keep up because it seems like a waste. I got it down to 12.8 around 1pm and noticed it wasn't charging very much when the sun is at the peak. The panels are mounted along a fence and have nothing but air below and around them.
    So I don't really know where to start. I covered up the panels and a bit later tried them cool and it was still acting weird. I was taking voltage from the panels and I would see 13v then pop up to 18v then back. Blips of 16 and 18. Should I look at the controller? Should I separate the panels? I'm looking for a step by step of the things I should test. I know full well that I should have better panels, better batteries and a better charge controller but times are tough. If this is what you had to work with, how would you proceed?
    (I do have another charge controller that I bought last summer when this same thing happened. Should I angle them to get the most out of the morning sun? What would you do?
    I'd take the controller off, and wire PV to the batteries. Monitor with a volt meter, at 14.8V they are fully charged. If they run down too quick, the batteries are shot.
    • DtommyD
      • Aug 2011
      Ok
      So I just looked at the battery and see 2 voltages one for standby and the other for cycle use @ 14.8 like you said. (I didn't notice that before - I only knew the 13.5)
      So just to clairify I'll take out the charge controller but I should take it off the battery at 14.8v right? I am the charge controller. Sorry for the dumb question I'm just trying to measure twice, cut once. I don't want to blow anything up.
