I live in NYC and do possess a Renogy 50 Watt 12 Volt Monocrystalline Solar Panel that I am using to charge a KYNG portable power station 540w (SGR-PPS500). The KYNG is at 47% and I've placed the solar panel by the living room window at my apartment. The KYNG does turn on as it detects charge coming from the panel but for the few hours of sunlight it seems to be stuck at 47% charge. Are there any suggestions or just wait for spring. Thanks.
Not charging well
Window glass can impair the performance of solar panels. Can you open the window? If not, perhaps take the system outside so it gets direct sun.
Might be useful to confirm the KYNG can be charged from the supplied AC adapter, and get a feel for how long it takes to see the charge increase from 47 to 48 and 49%. It will be different when charging from solar, but it will give you some sense how it works.
Also confirm that the solar panel is outputting useful power. Have you used it power anything else--even an incandescent light bulb?
SolarEdge 12.3kWp grid-tie, 19.4kWh, SW Idaho -
IF you really understand what the sun provides to allow a pv panel to generate electricity and charge a battery you would then do whatever is necessary.
As Srrndhound says above you would realize that a window or anything that blocks the protons in the suns rays you would move the panel outside.Comment
I wouldn't know how to connect a light bulb to the panel but I tried my multimeter instead. If I'm reading this correct then I think it's giving out about 36 Volts DC. I did it yesterday which was pretty sunny but in the end the battery is now at 45%. IMG-0347.jpgComment
Actually with the meter set at 0 -25 volts DC your panel is putting out just about 17 volts not 36 volts.I wouldn't know how to connect a light bulb to the panel but I tried my multimeter instead. If I'm reading this correct then I think it's giving out about 36 Volts DC. I did it yesterday which was pretty sunny but in the end the battery is now at 45%. IMG-0347.jpg
And depending on you loads the battery can be quickly discharged.Comment
The batery seems to be idle. It has 3 options for loads (usb, dc and ac) and none are in use. And it's cloudy today.Comment
Your panel likely is not getting enough direct sunlight through the window to effectively charge the KYNG. I suggest moving it outdoors if possible, or wait for stronger spring sunlight.Comment
As SunEagle noted, the meter is showing ~17V, with no load, I presume. Have you measured the output voltage while the panel is connected to the Kyng Power Station?
Is this a new setup -- the power station and the solar panel -- or has it worked ok previously? The Kyng manual says it can be charged from 60/80/100/120 W solar panels, with 120 W being recommended. The charging circuit might not activate if the input power is weak. The manual says when the unit is charging, the LCD screen illuminates. Is that happening? If not, try charging from the AC power adapter to see what normal charging looks like.
SolarEdge 12.3kWp grid-tie, 19.4kWh, SW IdahoComment
This is a new setup and the LCD screen does illuminate. I wouldn't know how to measure the output voltage while the panel is connected to the Kyng Power Station.Comment
Today I took some new readings. I tried posting pictures but I had some problems with that so ditched the idea. I had about 19.5V and 120mA. The power station input clearly states 12-24v. Although the power station's level has gone down to 42%.Last edited by Highlander1138; 05-11-2025, 03:36 PM.Comment
