  • billboe
    • Jun 2018
    • 33
    Adding 3rd String to Existing Solaredge System
    I installed a 11.25DC system back in 2019 which has been working great (definitely already paid for itself). And now, after purchasing an EV and with plans to build a garage/apartment next year, I'm looking to add more panels to the existing inverter. The current system is as follows:
    SolarEdge SE10000-US (10kw inverter)
    30x 375w panels w/ p505 optimizers (2x strings of 15)
    DC/AC oversizing - 113%
    I want to add 6x 410w panels using the s500b inverters (inverter oversizing jumps to 137%). The easiest option is just to add the 6 panels as its own string (the s500b minimum length is 6 panels) but it appears I may be sacrificing some efficiency with a short string??? With a new separate 3rd 6 panel string, SE estimates that I'll produce 19.21MWH. If I rewire some of the old panels such that I have the 6 new panels and 5 of the old panels in the 3rd string, the production jumps to 19.28MWh. Not a huge difference but I was surprised to see it.
    Is it the short string or perhaps uneven strings that is causing the difference?
    Thanks all!
  • billboe
    • Jun 2018
    • 33
    No opinions here? Do you need more details? Here is my original post from 2019 for this install. THANKS!!!
    • Mike 134
      • Jan 2022
      • 429
      Don't know enough about the products to give you an educated answer. That said I am an internet expert on many topics.
