  • Rade
    • Aug 2023
    • 145
    All kidding aside...
    This is my first year with a full solar rig (we're 5 months since the system activation). I have been riding herd over the meter and the monitoring app. Our system uses the Generac PWRView app (they shut down the web GUI that gave me a lot more data output). I take a daily meter read and can get the daily solar production off the app. I use the two numbers to determine how much power the house has used and how much should have been sent back to the grid for credit. Note: It also helps that I am retired and have nothing else to frickin' do than splice and dice metrics.
    The monthly statement is usually around 20kW less than what I calculated, but in the ballpark.
    My concern is that our house is a power hog. Don't care what kind of "Energy Star" appliances we installed, there were times with the old analog meter that I could hear those dials spinning. I am looking at the historical numbers of what we consumed in a given month last year over this year, are we using more or less power this year, how much did solar offset, etc. On the plus, with the arc of the sun moving Southward and our energy production reduced to around 6 hours a day, our meter is still showing an daily energy credit over the prior month. Not much, but it's still there.
    Rade Radosevich-Slay
    Tiverton, RI
      • 5209
      Originally posted by Rade
      "That's NOT the Port-a-John!"
      They are the well crew replacing the down pipe and pump of my well.
      One of the few jobs I would not attempt DIY. That partial leak was the
      biggest waste of energy I had ever experienced. Made me wonder
      what I should do to detect such a thing sooner? With the whole HVAC
      and electric energy situation running pretty smoothly unmonitored for
      some years, I estimated it had been leaking like a week before it
      affected my electric bill rollover reserve. Weeks after that I was working
      on installing the spinning disc meter when I noticed the pump never
      shut off. By then it was using a lot of energy, more than my solar could
      generate in winter over a 24 hour day.
      For those too young to have ever seen one, that is a real Superman
      phone booth, not a Port-a-Pottie. A hint of how I spent a 41 year
      career. Those were everywhere whan I was hired to design phone
      equipment in 66. The original 200w light is replaced by a 3w LED.
      When I retired they were gone, because we had managed to put a
      phone in the hands of every person in the world.
      The propane tank is still there, as a backup in case a long outage shuts
      down the heat pumps. Costs me $50 a year.
      I highly recommend identifying and putting numbers on energy
      consumers at home, that started decades ago at my previous place.
      There were days I came home, and that rotating disc was stationary,
      at least until something got turned on, many bills under $20 total. If
      the place is an energy hog, where exactly is the energy going? That
      is the first step to real improvments. Here I used 120VAC and 240VAC
      versions of the Kill-A-Watt meter to track down some hundred loads
      on 60 circuits, over a couple years. Nice project for someone retired.
      In some cases "Energy Star" appliances really helped reduce
      consumption, other things took more engineering. The story is ongoing,
      I am still finding ways to shave down use by subtle continuous standby
      loads like CO/fire detectors, garage door openers, battery maintainers,
      communication amplifiers, and security devices. Improvements have
      allowed me to turn on some luxuries at no cost.
      Some good numbers allowed me to estimate just what size solar might
      eliminate my energy charges, and completely avoid connect fees to a
      gas supplier. Presently this ancient but accurate spinning disc moves
      right (counting up) when solar is generating credit, the opposite when
      I use more than generation. A glance at the disc gives me an idea of
      what is happening, the numbers give energy reserve when compared
      to those at April true up. About now is the peak, 14,000 kWh heading
      into winter. good luck, Bruce Roe
      • DanS26
        • Dec 2011
        • 987
        There are many energy monitoring systems out there that work well to identify loads.....I DIY installed the TED System many years ago. Here is a screen shot of some of the 28 circuits I monitor in my service.....
        • DanS26
          • Dec 2011
          • 987
          My SO rolls her eyes when I notice something is not right....like the iron or sewing machine is left on in her workshop or I leave the lights on in my garage workshop. More than once I spotted a well pump running when it should not be....a toilet tank flapper not closed, etc.
          If an AC or heat pump is pulling more amps than normal then I know. I monitor how many kWh my EV is using and how well the solar system is working, An old saw says "If you measure it, then it will get better" and I believe it.
            • 5209
            Another note, when everything was in place at this location, the
            steady load with everything turned off was about 300W, or 2600kWh
            a year. Perhaps not so much for some, but pretty big in my use.
            Most of this was eventually tracked down to older stuff that was
            either on 24/7 (garage door radio, fire det, etc) or machines using
            energy with the switch in the off position (older electronics, TV
            remote control circuit, doorbell transformer, etc). Most of these
            were in the 2 to 5 watt range. Not much can be done about a
            couple dozen GFI outlets. Some were just failures, found a locked
            fan motor in the attic. After a lot of effort over time, tracking down
            every individual circuit, these were reduced to some 60W.
            Generally a single measurement told a circuit story, no need for
            continuous monitoring. Bruce Roe
            • DanS26
              • Dec 2011
              • 987
              were in the 2 to 5 watt range. Not much cn be done about a
              couple dozen GFI putlets. Some were just failures, found a locked
              Pretty much agree except for solar monitoring. Like you, I run two matched Fronius 7.5 inverters. On a daily basis I monitor the output of these two inverters....it tells me immediately if there is any difference in output which if so I need to investigate. I do not have to use the Fronius tools.
              It just a simple matter of opening the TED app and I know....in a matter of seconds each day and I can monitor anywhere in the world.
              • DanS26
                • Dec 2011
                • 987
                Identifying vampire loads is one thing....knowing when they come and go instantly is entirely different.
                • Stratton_Oakmont
                  • Sep 2023
                  • 17
                  Originally posted by scrambler
                  Does your emphase system includes a monitoring of your import / export from / to grid?
                  If not, you need to install your own monitoring, like the Emporia Vue, so that you can compare what you measure as import / export to grid versus what PG&E says you import / export.
                  The emporia Vue will also allow you to monitor house loads which may help identify if you have something using more than it should.
                  I finally installed the Emporia Vue 2 monitoring system but I have four mains feeding my 200 amp breaker. Therefore, I'm told I can't monitor the mains and my best bet is to just monitor all of the breakers for usage. This will require two more Vue systems to be installed, which my panels do not have the space for. Any other monitoring solutions that can monitor four mains?
                  • scrambler
                    • Mar 2019
                    • 503
                    If the 4 mains' wires are close, you can pass the CTs around two wires of the same phase.
                    If the regular CTs are too small, they make large band CTs you can use instead.
