  • rgensler
    • Nov 2022
    Recommendations for grid-tie ground mount system and solar ready panel
    Hi,
    We've gone through energy upgrades to our house which included air sealing, insulation, removing the gas appliances, and installing cold-climate heat pumps. The next phase is to install 12Kw grid-tied ground mount solar. I would like recommendations on best practices/equipment.
    We need to replace our trailer meter and would like a recommendation on a 200 amp solar ready weather proof pass through load center. I need a couple of breaker slots to feed a subpanel at the pool but otherwise the line would pass through to the main panel in the house.
    This will be mounted on a bit of a hill with soil and some rock. Freeze depth is around 36". What is the recommended rack system I should look at?
    What is the recommendation on panels, inverter, etc?
    Thanks!
  • organic farmer
    • Dec 2013
    • 663
    When you get quotes from local licensed installers make sure that you include a battery-bank. It is normally an option on all manufactured systems, but the sales staff will usually push for you to ignore that option.
      • 5209
      If you will see snow, study the sticky Snow Tolerant PV Mounting
      at the beginning here at Solar Panels for Home.
      Cold climate heat pumps have been supplying all HVAC here for
      4 years. Bruce Roe
      • peakbagger
        • Jun 2010
        • 1566
        If you have not done so spend a few bucks and buy the Solar Power Your Home for Dummies
        • sdold
          • Jun 2014
          • 1451
          Batteries might be nice to have but aren't required and add to the cost. I can see the wisdom in planning ahead for them in case they will be added later.
          • azdave
            • Oct 2014
            • 790
            I agree. No harm in having them quoted but plenty of us have no use for energy storage and the ROI point can take a big leap into the future if you don't really need them.
            Dave W. Gilbert AZ
            6.63kW grid-tie owner
            • SolTex
              • Mar 2022
              • 74
              Originally posted by rgensler
              Hi,
              We used the IronRidge XR ground mount system to install a 15 kW system behind our house in West TX. I feel it is a good system and pretty simple to install. The company web site has a design tool that allows you to input your desired number of solar panels and see exactly what the whole assembly will look like. Check it out.
              Strength meets flexibility. The IronRidge Ground Mount System combines our XR1000 Rails with locally-sourced steel pipes or mechanical tubing, to create a cost-effective structure capable of handling any site or terrain challenge.
              Enphase 15kW: (40) LG380N1C, IQ7+, (2) 10T storage
