I want to know if others are having similar problems with their PWRcell systems? Ours went live in Mar 2020, and worked perfectly till Mar 2022. Then the PVRSS sub-system started turning off the roof-top panels, almost randomly. This has been going on for > 6 months, with extended periods of 1/3 to 2/3 of the panels off-line. We were originally told the SNAP units were faulty and needed to be replaced with a new revision. All 3 have now been replaced, then we got a S/W upgrade, and then finally some fine tuning of various internal parameters. After all this, the number of PVRSS lock-out errors has been reduced, but the system still trips off-line.
From our frustrated local installer, this appears to be a common problem in our area. The question is how wide-spread is the problem across the nation? FYI, to date, Generac has been less then helpful.
