I really appreciate all the good information on the forum. I am new to solar energy. I've only made one panel, the usual, 36, .5v cells giving an 18 volt panel.
I quickly discovered that if I could use higher voltage cells I could get a panel with higher voltage and wattage. But before I make one I want to calculate what the wattage would be if I used 9v cells, 30 of them in the panel. That way I could save on the cost of glass and frame and encapsulator, etc. Each cell has Peak Current of 70mA and Short Circuit current of 75mA. Can anyone help with what wattage that panel would be?
Secondly, would you have to use heavier tagging and bussing wire? How about the diode?.....and anything else that I would have to take into consideration. Thanks in advance.
Tag
Tag
