I am lOoking at a pv system set up in the folliwing way:
3x3 240w pannels / 72 Vdc
Flexmax 80
48 v batterie array built from Trojan L16GAC (6V 390 Ah @ 20hr), bought new 18 month ago
Outbackpower inverter FX3048T
4 month ago the system was aparently working fine. Then it was disconnected in the following way.
- AC load disconnected
- Controler disconnected from batterie bank
- solar pannels disconnected from controler
- batteries stayed connected to inverter all the time
I tested the system today. Battery bank over all 8 batteries measures 9.6 v, some single batterias show 0 volt.
The pannels read 102 v open circuit.
The controler does not start up as battery voltage is to low, must be minimum 10.5 v acvording to manual.
I suppose the batteries where drained by the idleing inverter over the 4 month without charging them. Obviously the batteries have to be precharged to start the controler again. But what can I expect from the batteries? Are the damaged after discarged so deeply?
I apreciate any input, thanks to everybody jumping in!
Chris, Mexico.
Flexmax 80
Chris, Mexico.
