Hi,
I have a couple questions and I'd like to thank anyone who offers their insight in advance. I'm planning on building a small home on my land in the next year or so, and for the time being, I wanted to install a small system where I'm living now. I'm most concerned with reducing my electric bill.
Here's what I'm working with:
(32) Sunman E-Arche SMS105M-2X12 mono-si flexible panels
Rated Maximum Power 105 W
Current at Pmax 8.27 A
Voltage at Pmax 12.7 V
Open CIrcuit Voltage 15.4 V
Maximum System Voltage 600V
Maximum Series Fuse Rating 20 A
SolarEpic Smart Grid Tie Inverter YC-B101
1000W
DC Input: 20-45VDC
AC Output: 115VAC(90-140)
Cantex 8X8X5 PVC Junction Box (Empty)
100 Amp Shut Off
(Don't think I'll need this for now, but I included it just in case)
EPEVER Tracer 4210AN MPPT Charge Controller
Voltage 12/24V/LI
Current 40Amp
Max PVoltage 100V
Max PV Input Power 520 W 12V 1040W 24V
I realize that the equipment I have isn't the best, especially the grid tie inverter. However, I want to get the most life out of it that I can and I was wondering how many panels/watts I can safely connect to it?
Do you recommend that I purchase branch connectors or a combiner box and if so, which one do you recommend?
Since the grid tie inverter operates at 20-45VDC, how should I wire the panels together for best results?
The distance between the panels and the wall socket (to plug in the grid tie inverter) is about 15ft. What wiring will I need?
1000W
DC Input: 20-45VDC
100 Amp Shut Off
Voltage 12/24V/LI
Current 40Amp
Max PVoltage 100V
