You can always have a conductor (bus or wire) that is capable of carrying more amperage than the breaker/fuse protecting it.
And I think most panels you can replace the main breaker for it (ex. 200A) with a smaller one (ex. 100A)
Embedded in the concrete wall?
Not just inside a stucco wall or surface mount?
The builder must have really hated people.
So I think what you're saying that you currently have a combination meter-panel with a 100A breaker. And that feeds a 100A subpanel.
So you currently have
<meter>===<100A_breaker>==<2AWG_wire>== <100A_rated_subpanel_with_household_loads>
And you're planning to change that to be:
<meter>===<100A_breaker>==<2AWG_wire>==<200A_rat ed _subpanel>==<100A_breaker>==<2AWG_wire>== <exist_100A_subp>
.................................................. .........\\==<40A_breaker>==<inverter>
(ignore the periods, they're there to ensure spacing is good)
I do not know if you would have to have a 100A breaker at the top of that subpanel, or not.
I think you could do a 100A breaker at the top of the subpanel (fed from the meter panel), a 100A output breaker, a 40A backfeed breaker, and use a panel with a 125A rated bus and be compliant to the 120% rule. (125A * 1.2 = 150A)
I'm not a licensed electrician, but I think that'd meet the requirements for protecting the conductors. And probably be cheaper/more readily available than a 200A subpanel.
(and you should probably check the 2AWG for 100A - I didn't look that up, but since that's what you currently have for 100A from the main to the subpanel...)
The situation is that for residential accounts only one meter is allowed. So, I can't do a supply side tap. The integrated 100-amp combo meter/panel is old and I have not found an UL approved bus tap (the connection from the meter to the breaker is a bus, not a cable). The problem is that the combo meter/panel is in a concrete wall. And replacing it and/or making a tap (before or after the breaker) will be expensive.
The cheaper solution, in this case, would be to put a small 200-amp panel between the 100-amp combo meter/panel and the 100-amp distribution panel. Put a 100-amp input breaker and one 100-amp breaker to feed the distribution panel and one 40-amp breaker for the inverter. The only problem I have is that I'm not sure if this is acceptable under NEC. Does the 120% rule apply only to the panel where the inverter is connected, or do I need to replace the service and feeder cable with 200-amp cable?
