Most Popular Topics
Help diagnosing non-producing SolarEdge system (DC overvoltage)
Hah, the system at my old house had three optimizers fail within two years, all repaired by the original installer under warranty at least. However, they never sent alerts and had it not been for me monitoring the panel level outputs, would have not been caught and repaired (at least quickly).OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
I'm just thinking that this system obviously was functional at one point so the settings in the inverter shouldn't be a problem, and that unless the thing updates automatically I'd assume that the firmware was what was on the unit when it came out the box unless the installer updated it. He didn't even connect it to the internet so I'd say that's doubtful. That's why I kinda ruled that stuff out. But by all means explore all possibilities.
Both will auto upgrade if they are particular versions but in this case the inverter was not connected to monitoring and was then manually upgraded still without monitoring, then attached to internet...OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Likely they will send an hdwave inverter out. Are they contacting an installer or expecting you ( registered installer ) to handle install. Install should be covered under warranty. Make sure that they go into monitoring and replace the inverter serial number instead of setting up a new system so you keep past production data.OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Understood. But that also may say something about the general level of users' concern or basic product knowledge of what they bought when, as perhaps in this case, one of the big selling points of SolarEdge is panel level, or any monitoring and the original user (apparently) either didn't know about it or didn't care. Not much help if it's generally ignored and maybe in such (common ?) situations not worth the increased probability for problems the added complexity creates.Comment
in this case the monitoring ( connection) would have prevented the problem with automatic update, though new user would have to get access..OutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Simpler systems fit for purpose are more reliable. More system complication for features not needed or understood causes unnecessary problems as perhaps evidenced by all the posts around here relating to SolarEdge (perceived) problems, and a casual reader of this forum doesn't need to be technically astute to see it.Last edited by J.P.M.; 06-27-2019, 05:15 PM.Comment
Likely they will send an hdwave inverter out. Are they contacting an installer or expecting you ( registered installer ) to handle install. Install should be covered under warranty. Make sure that they go into monitoring and replace the inverter serial number instead of setting up a new system so you keep past production data.Comment
I understand this thread is over a year old, but I’m curious if dmage ever got the system working with the replacement inverter?Comment
