Coming Soon to NJ - 12.35 kW Hanwha DUO-G5 + SolarEdge Inverter/Optimizers by GPE
Our guy came on a day when everyone happened to be home and he gamely waited by the meter for the five or so minutes that it took to finish baking something thatthat had been in the oven. We momentarily lost power a few times over a span of about fifteen minutes, but it was pretty painless. PTO came I think the next day. -
Well just to keep the updates rolling guys...
I DocuSigned our Part 2 of the Interconnection Agreement with JCP&L the other day and GPE stopped by to swap out the SREC meter for a working one, so we're all zeros, ready and waiting....
Any day now!
Be on the lookout for the JCP&L electrician. He was a total ninja. The morning before I received the PTO email from GPE, I noticed a voltage drop when both my UPS' clicked, as if the laser printer came on and I thought nothing of it. Early in the afternoon there it was, the new meter, and couple hours later the PTO email came. Neither of my security cameras captured when JCP&L showed upThe house didn't lose power when the meter was swapped.
Very exciting!Leave a comment:
Any day now!
I took a few readings of the big aluminum heatsink on the side of the inverter with the palm of my hand. On a 90+ degree day while my SE11400 was cranking at >10kW, it's "very warm" to the touch, never even became uncomfortable leaving my palm on it. In comparison, a toasted roll will get uncomfortable, fast
And I took a reading with an IR thermometer, the hottest point I could get was 107F. It's a bit tricky pointing it at the aluminum surface. Pointing at it from the sides max I could get was around 90F, but I knew it's hotter than that. I pointed it down the fins from above and hottest I could get was the 107F.
In all seriousness, it will not make any difference as far as heating up my garage in the winter. I've only ever heard the fan come on once, and it wasn't even that hot that day.Leave a comment:
Even then you're talking about fewer than 230w/hr, and how often is it really going to be cranking along at maximum capacity? Hopefully a lot, obviously, but we aren't exactly in Arizona hereLeave a comment:
A bit more with the SE11400 obviously.... mini toaster oven?Last edited by NJturtlePower; 08-20-2019, 02:28 PM.Leave a comment:
So if I'm understanding correctly, if the efficiency of my 7600w inverter is 98%, we're looking at a rough maximum waste heat figure of 2% * 7600 = 152w/hr?Leave a comment:
Exactly my feeling about equipment protection and utilizing dead basement space.
I'm happy I opted (per recommendations from here early on) for that vs everything outside, and as you said the only complication is an extra external disconnect and a bit of IN/OUT conduit runs.
I'm 1-week in now waiting on my PTO/Meter Swap so just that much closer.....Leave a comment:
Fwiw, we opted to have the inverter and srec meter mounted in the basement, next to our electrical panel, and are ethernet connected. There's plenty of space for it, so keeping it out of the elements seemed wise. Plus, could performance be affected if the inverter is itself being heated by direct sunlight?
We haven't had a truly clear day yet, so I don't know that the system has ever been going full gas, but so far the inverter has been effectively silent and doesn't throw off any appreciable heat. The only drawback to this setup I see is the fact that it required two additional penetration to run the exterior emergency disconnect. Not a big problem, but fewer holes punched through exterior walls always seems better.
I'm 1-week in now waiting on my PTO/Meter Swap so just that much closer.....Last edited by NJturtlePower; 08-20-2019, 11:40 AM.Leave a comment:
@NJturtlePower, Thanks for writing up this great thread. I'm in central NJ (East Windsor) and looking at solar now so this is a very informative thread. Do you know if GPE or Costello roofing gives you anything for referrals? I'm going to call them up and wanted to get you something if possible. If you need to contact me, my username here is my gmail account. Thanks again.
I'm kinda OCD (obviously), and wordy to most reading these things, but it is what it is and figure SOMEBODY might be in the same frame of mind looking at every possible detail some day.
I just emailed my Sales guy at GPE, Tim DeSevo about any referrals... I'll let you know and appreciate it!
UPDATE: robstrash There is in fact a very generous $500 referral bonus offered by GPE- Email sent to your Gmail.
@NJturtlePower, Thanks for writing up this great thread. I'm in central NJ (East Windsor) and looking at solar now so this is a very informative thread. Do you know if GPE or Costello roofing gives you anything for referrals? I'm going to call them up and wanted to get you something if possible. If you need to contact me, my username here is my gmail account. Thanks again.Leave a comment:
