LOOKS GOOD! who manufacturer's that racking system? looks very tall to me!
Most Popular Topics
Have 48 panels, want to install (flat roof, SFH, SF CA)
Thanks! Pretty sure it's Ironridge XR100.
Question to the forum -- our inverter is a SolarEdge HD10000, and of course I'm very interested to be able to see the monitoring app(s), is there anything I should ask our installer in terms of networking or passwords to access the monitoring system?Comment
It would be an SE10000h not HD10000Thanks! Pretty sure it's Ironridge XR100.
you want to ask for full access and owner
if you have good internet you want them to use the ethernet connection or third party wireless adapter, not cellular GSMOutBack FP1 w/ CS6P-250P http://bit.ly/1Sg5VNHComment
Panels were installed:
Pg&e took awhile to issue our permission to operate, but it finally came through.
The system just went operational!
Thanks again everyone on the forum here who who helped with advice and encouragement.Comment
First day of production. Partly foggy in the am otherwise clear. 58 kWh. PVWatts predicted 64 kWh so it's not far off.
10B50F66-96BB-4034-B786-E7732AFBFD30.jpegComment
I am glad it met your expectations. At that rate you will cover your consumption in less than ten days. Thanks for keeping us informed about the progress of your build.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
Update on this old thread.
- Everything has been working well.
- No issues during a recent wind storm.
- Solar production has been 30% above PVwatts estimate/model but this is leveling out to 20%. Not sure why it under counted. I was told these are really good panels, it might be that, or the unusually dry season.
- One roof leak from an improperly sealed drain. Interestingly, to dry out the affected interior room, we used alot of electric heat for 10 days. Our electric consumption was net positive during this time.
- Otherwise we are net positive for electric production just about every day. We will slowly switch our appliances over to electric as they wear out.
Thanks to everyone on this forum for all the invaluable advice.
- One piece of helpful advice was to use one company for both roofing and solar to reduce finger pointing when something goes wrong. I've learned alot about roofing over the past 6 months!
- Likely the best advice I got was to tilt the panels. The fact they are self-cleaning is really nice.
Happy to provide more details!
Thanks again for the update. My CCA, Sonoma Clean Power, just offered incentives for installing a HPWH. In that process I also discovered additional rebates. I know Clean Power SF is still rolling out across the City but hopefully they will offer similar incentives in the future.
Hopefully, you got through the Public Safety Power Shutdowns late last year?9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
Could be several contributing reasons. Two of the more likely culprits might be:Update on this old thread.
1.) The input to PVWatts is not representative of the site conditions.
2.) The 6 months prior weather you've experienced may have been more conducive to PV generation than the weather data PVWatts uses for the same period.
The model help/info screens will tell you that even with input that's close to the actual array design parameters, yearly actual output might vary +/- 10 % or so from what the model pukes out.
Monthly output variance is maybe +/- 30 %.
6 months of output might be somewhere between the two.
My money would be about 2/3 of the diff. due to model input that's different from what's on your roof and the rest due to weather variation.
FWIW, data on running totals and ratios of actual vs. what the PVWatts model gives for my array from 10/17/2013 onward:
Using running 31 day totals:
Running 31 day actual total output/running 31 day PVWatts modeled total output:
Average: 0.9980
Minimum: 0.6426
Maximum: 1.3023
Std. Deviation: 0.0996
N =2,304
Using running 183 day totals:
Running 183 day actual total output/running 183 day PVWatts modeled output:
Average: 0.9824
Minimum: 0.8943
Maximum: 1.0756
Std. Deviation: 0.037
N = 2,121
Using 365 day totals:
Running 365 day actual total output/running 365 day PVWatts modeled total output:
Average: 0.9960
Minimum: 0.9575
Maximum: 1.0530
Std. Deviation: 0.0221
N = 1939
Data is from my array and deemed accurate but not guaranteed.
Your array results, output and actual vs. modeled output will be different.
I offer the above for information purposes only.
My climate has less summer/winter variation than most others with respect to irradiance. My thinking is that lower variation may help explain the lower 183 and 365 day variation in the PVWatts output vs. actual.Last edited by J.P.M.; 02-24-2020, 02:16 PM.Comment
Updating this old thread with some numbers. The system is consistently generating 4+6+5+3 = 18 MWh per year. CleanPowerSF tells us we’ve earned $1000 or so in credits. As we go all electric from natural gas we will likely consume as much or maybe slightly more than we produce.
Thanks again to this forum for all the guidance!
891B5B03-1594-48DD-B1D8-E7DC5830ECDF.jpegLast edited by chuckledog; 10-26-2021, 02:48 AM.Comment
Update on heat pump water heater -- we've been using a Rheem Performance Platinum 80gal for much of the year. This is using about 100kWh per month or about 1 MWh per year.
We're switching our clothes dryer to electric -- that'll also run about 1 MWh per year.
The rest of the house appliances & lights combined run about 2 MWh per year.
The EV (Nissan Leaf, base model) with our current driving patterns uses about 2 MWh per year.
So that's 6MWh per year total -- leaving about 12 MWh per year extra.
So, we're putting it into home heating. We ran an HVAC local calc. It's not quite enough to heat our home, even with a favorable TOU rate plan, but it's enough to heat the basement and part of the upstairs. We're installing an AWHP tied into a radiant slab. We'll keep our old forced-air gas furnace around for the rest of the upstairs, the cold nights, and the power outages. (We've opted to not look into battery backup / Powerwall type stuff). The house won't be "net zero" but it felt like too big of a bet to shoot for that. If we overshoot our energy budget on electric, it can get expensive quickly. Maybe next decade when AWHP tech is more mature -- or maybe by adding mini splits.
As of right now we're in the middle of a remodel, using electric space heaters to keep warm with half our walls missing. Slightly crazy but the family seems supportive (again SF only gets down to 40F in the winter, if we had "real" winters I would be hating life right about now). Our gas furnace has been shut off for a year and our gas bills are a tenth of what they used to be.
My better half points out that if we can get our usage down to tier 1 in electric and tier 1 in gas, we'll get charged lower rates from PG&E for both. So shifting some but not all of the energy load from gas to electric has been very practical. We used to dip into tier 3 for gas which gets quite expensive.
Anyways thanks again to this forum for all the invaluable advice, I hope the information in this thread is useful to others as well.Comment
Thanks for the update.
I have a friend in Southern California who has radiant heat and uses a separate HPWH for that, He only turns it on during late Fall through early Spring, As you know radiant does not take high temperature water.9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
We are running into this issue… our HPWH doesn’t like recirculating the hot water… might be able to insulate our hot water return pipe to get past this.
Heat+Pump+w-recirculation+1331.pdfComment
I used a temperature sensor on the return line on my recirc system to turn off the recirc before the warm water got to the cold inlet. As far as using an additional HPWH for the radiant I don't know if the typical setting of 80 degrees will be a problem initially. My friend actually had radiant wall radiators which ran at a higher temperature and he was using a different model. It may not be worth the effort since gas is still the most economical9 kW solar, 42kWh LFP storage. EV owner since 2012Comment
Update --
We're in the thick of the remodel, picking out tiles, countertops, etc. However the drywall is up, and *most* of the HVAC has been running now for 2-3 weeks.
The big news is, after a couple of scary days with high electric bills, we're back in the "green" producing more electricity than we use. This is in late March / early April, where we have good amounts of sun, and relatively moderate temperatures. Our gas is (temporarily) completely shut off, and we're heating the entire home with a combination of radiant and electric space heaters.
Energy supply:
- 48 solar panels, 12.7 kW peak panel wattage, clipped by our 10kW inverter. 3 years of history show that this rooftop system generates 19MWh per year
- PG&E service with "E-TOU-C" rate and net metering, without this there's no way we could keep up with the winter heating load
Energy consumption:
- Space heating:
- Chiltrix CX-34 air-to-water heat pump, heating PEX tubing (radiant slab + staple-up under-floor), 40000BTU modeled load
- 1 750W electric space heater, heating
- Domestic hot water heating:
- 80 gal Rheem heat pump water heater
- Recirculating hot water pump (mainly to conserve H2O)
- Automobile:
- low-end electric car, 200 miles / week, mainly charged at home
- Appliances:
- Electric dryer, non heat-pump
- not many other appliances hooked up. Just a microwave, toaster oven, induction hot plate, washing machine, fridge
Note the purple line shows the ambient temperature, the blue lines show energy consumption in excess of production, and the green columns show production exceeding consumption. Green = good. The green kWh get "banked" for us for use in the colder months of winter.
The big blue spike was a single 80kWh day. This was pretty terrifying, but likely corresponded to the system warming up our 1600 sq ft concrete slab from 52F to 63F. If the system had continued using this much money per day, we'd have to shut it off! but it didn't -- we went into the green.
Granted the temperatures have been higher. So it's still up in the air whether this system will break even. I wanted to share the early positive indications and will update with more data in a few months.
