Hi,
Plans are being finalized for my house for a roughly 20.4kw solar system, currently made up of 69-70 295W panels and probably 3 SMA 8000US inverters. Due to the flat roof with a variety of skylights, other obstructions, and fire dept restrictions, the panels would be located in a lot of different groupings (no less than 7 arrays), some of which are restricted to lower mounting angles than others for various reasons (big arrays get too tall, one array could shadow another, etc).
The installer is a good guy but newer to the business and still going through some learning curve. The latest plans submitted to me would blend groupings of different angles onto at least one of the SMA inverters. Ie, one inverter that has 24 panels assigned could have 20 panels mounted @ 10 degrees + 4 more at a different angle (20 degrees). Or if that example fails with regards to string practices without even taking MPPT into account (?), then use "16 @ 10degrees & 8 @ 20degrees" for the example.
I've seen a couple comments on the forum from experienced folks here saying (if I understood correctly) that all solar panels assigned to a single central inverter that has 1 MPPT must be mounted at the same angle or it will confuse the MPPT system. Questions:
1) Is this "confusion" significant -- is it likely to cause a bigger loss of efficiency than lowering all the panel mounting angles per inverter to the lowest common denominator?
2) I did a few different searches on the web and couldn't find any information anywhere that would give me something solid to show the installer that mixing angles per inverter is a bad thing. I think I even checked an SMA install manual and didn't see a mention. Why is info so scarce on this? Can someone point me to anything definitive?
Much appreciated!
Much appreciated!
