PV wire junction question
congrats!!!!!!!!!!!well, this got side tracked.
I am not redoing my roof penetrations to add a soladeck.
My connections are not on or even within 2 feet of the roof surface. The junction box is in the attached garage.
I hate split nuts, mostly for the tape. But, i hate spending an extra $60 for the burndy unitaps. So i will likely just do split bolts. If the burndy unitaps was the right connector the decision would be easier.
unless, the mc4 connectors (just like on each panel) are ok inside a junction box. I already have them and they are xleaner than split bolts and tape.
I understand that insulation requirements for ac vs dc are about the same. But it seems that terminations and connections are more important with dc
also, i have two strings. They will see a max of 10a and 7a, so not a huge current load.
Also, on a side note. I got my permission to operate in 3 days! Submitted monday evening, received the pto email wednesday night.
I use a zip tie over the top of tape, to keep it from uncurling .Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
The Unitaps are the correct part for the job. These style connectors are widely used in the industry. The failures and corrosion NewBoston mentioned are due to using the wrong connectors or improper installation. Read the installation instructions, and use the correct torque, and they won't be an issue.Well, this got side tracked.
I hate split nuts, mostly for the tape. But, I hate spending an extra $60 for the Burndy Unitaps. So I will likely just do split bolts. If the Burndy unitaps was the right connector the decision would be easier.
Unless, the MC4 connectors (just like on each panel) are ok inside a junction box. I already have them and they are xleaner than split bolts and tape.
I understand that insulation requirements for AC vs DC are about the same. But it seems that terminations and connections are more important with DC
Also, I have two strings. They will see a max of 10a and 7a, so not a huge current load.
Also, on a side note. I got my permission to operate in 3 days! Submitted Monday evening, received the PTO email Wednesday night.
MC4 connectors can only be used if you are still running PV wire. THHN has thinner insulation, so the plastic housing of the connector will not seal to the wire insulation.
If you want a cheaper option, you can just use butt splices. Either insulated, or bare and add heat shrink. Just don't buy the cheap ones you get at the auto parts stores. Many are only rated for 24V. The only problem with crimping is that you would have to cut them out if there is a problem. Just leave yourself a little extra wire in the box.Comment
Not sure if this is applicable to everybody, but I've found that the 773 wago push nuts and the 221 wago snap nuts (both 600v rated and 221F heat rated) used with a snapnrack nema-3 rated j-box. Their maximum size is #10 awg, perfect for PV wire.Comment
