  • swbrains
    • Oct 2017
    • 22
    MC4 cable size
    As part of my research for setting up a simple solar panel (just a single 100W panel to (re)charge a single AGM battery), I have been doing lots of calculations online for the size of the wire needed between the panel and the charge controller/battery. In my case, I will be forced to have the panel on the back of the house, but the battery and charge controller would be in my garage at the front, at least 75-85 "cable" feet away accounting for vertical wire travel and some slack in the attic.
    After using some online calculators to determine wire sizes, I always seem to come up with needing some very large wire sizes -- around 6 AWG to 4 AWG -- depending on how much voltage loss I want to tolerate. If I played with slightly higher losses and the shortest possible cable length, I could get it to produce an 8 AWG cable size requirement, but no calculator produced a 10 AWG cable size for these parameters.
    So while doing some online research, I came across a couple of companies selling various solar components (panels, controllers, and cables, etc.). A couple of them had MC4 extension cables like this one: https://www.civicsolar.com/product/m...-pv-wire-150ft
    I'm confused by this. Why would a company make/sell a 10 AWG cable with MC4 connectors (so it theoretically was designed to be used as one long length) to be connected to a solar panel if the voltage losses over 75 to 85 feet seem to demand #6 or #4 wire to keep the losses at an acceptable level? I'm sure I'm not understanding something about wire sizes used to connect a panel to the controller, but this confused me based on what I've been seeing in various wire size calculators.
    Thanks for any clarification anyone can provide.
    Typically, long MC4 extension cables could be used when several panels are wired in series, raising the circuit voltage to a high enough level that the voltage drop is small. In other words, the same 0.5 V drop is a big deal on a 12 V circuit, not a big deal on a 48 V circuit. The heavier wire requirement you are running into is a consequence of using a 12 V panel (17 Vmp, or perhaps 15 V on a PWM controller) as opposed to a larger 20 V (60 cell, 29 Vmp) or 24 V (72 cell, 35 Vmp) panel.
      • 5209
      If a pair of those extensions caused a loss of 4V, it would be a big hit to a 12V system. But I have similar
      wire runs out to strings of 12 series panels, running at 400V. My system can afford that 1% lose, that might
      be 33% for you. Bruce Roe
      • swbrains
        • Oct 2017
        • 22
        Ah, now it makes sense. I was totally not thinking about a higher voltage with multiple panels. Thanks!
        • frankiek3
          • Oct 2017
          • 18
          They are also cut in roughly half with so the ends with female and male MC4 connectors go to the panel.
