I think you are about as informed as you want to be, or as willing to put in the additionsl effort for, at this point. Make your decision, your eyes are open, you know the risks for various options. Its always a dice roll. Make sure that contract is solid and reflects the verbal statements and has the model numbers of equipment and make sure you are there when it is installed and when the inspector does his work. Maybe he will be friendly enough to allow you to ask a few questions about the install and discretely ask about the quality SC work in your area. Good luck!
Most Popular Topics
SolarCity Isn't Looking So Terrible
What are your thoughts on solar edge's performance when it comes to cloud shading vs string inverters without optimizers? Does it give any additional benefits? One of the sales rep is telling me it performs better during a cloudy day and I'm thinking this is BS.Comment
CS6P-260P/SE3000 - http://tiny.cc/ed5ozxComment
I don't have a string inverter based system to compare to, but my Solar Edge system (which I really like) seems to perform very (likely equally) poorly in cloudy days. When a cloud is in front of the sun, unless it's a small cloud, it tends to block the light to my entire array. Our July and August in NJ has been unusually cloudy/rainy and I can get anywhere near as many KWH as I did the last couple days of JuneComment
I don't have a string inverter based system to compare to, but my Solar Edge system (which I really like) seems to perform very (likely equally) poorly in cloudy days. When a cloud is in front of the sun, unless it's a small cloud, it tends to block the light to my entire array. Our July and August in NJ has been unusually cloudy/rainy and I can get anywhere near as many KWH as I did the last couple days of June.
Yes, I think the optimizers won't help much for clouds, but if you have a tree branch or power pole or in my case it would be a ridiculously large chimney marching across the array there is likely some nice benefit there.Comment
if they bother you a lot. How frustrated are you; that is what is giving decent cloudy output here? Others
don't approve, your call. Of course added panels would overload the plant if pointed south under good sun,
so they should be oriented some other direction for benefit then. Bruce RoeComment
I don't think there is much doubt that on a partly cloudy day, giving each panel its own mppt will result in more raw output. Conversion efficiency matters too, but if we take as given that there is no difference between systems in that respect, the real question is whether or not the (small but measurable) increased output is enough to justify the additional complexity of the system (and the failure risks that follow). I don't think you'll find an objective answer to that question, so it really comes down to risk tolerance and preference of the homeowner / installer.
Perhaps the OP confused what the rep was referring to, or the rep is B.S.ing.
Bottom line for me, FWIW, no/little shade = string inverter.Comment
I've oversized my array to help with harvest in winter, when it's cloudy for weeks at a time. Under cloud cover I get 10% or even less, of my array output.
If the photons are not there, optimizer or MPPT cannot help.Powerfab top of pole PV mount (2) | Listeroid 6/1 w/st5 gen head | XW6048 inverter/chgr | Iota 48V/15A charger | Morningstar 60A MPPT | 48V, 800A NiFe Battery (in series)| 15, Evergreen 205w "12V" PV array on pole | Midnight ePanel | Grundfos 10 SO5-9 with 3 wire Franklin Electric motor (1/2hp 240V 1ph ) on a timer for 3 hr noontime run - Runs off PV ||
Ah, so the rep is indeed BSing. Can't trust any of these installers..everyone has their own little lie.
I told the rep SolarCity most likely will give me the regular string inverters and not solar edge with optimizers due to the fact that I have very little shading..and the rep said "but clouds, we get clouds, that's a shade". I didn't think any optimizers would help with that.Comment
You want to come and install the panels for me? I can't find anyone better than Solar City here because the above BS are what is coming out from local installers....how monocrystallines will break in FL and Solar edge inverters will give me 30% more power when it's cloudy vs standard inverters. The best local installer I have found only has 6 reviews, been established for 2 years, and only provides me with a 1 year bumper to bumper warranty.
So your condolences isn't doing a thing for me unless I contract you to install the panels for me.Comment
Take what you want of the above. Scrap the rest.Comment
My condolences are not meant to help your solar ignorance. The best thing you can do for yourself is get informed. FWIW, I'm not an installer and I don't have that skill set, but I probably forgot more about solar energy than you'll know for quite some time, and my experience watching how SolarCity screws up jobs and people is perhaps somewhat unique. as for my possible aid, prior to retirement 15 years ago, my consulting fees as a P.E. were ~ $150 /hr. Your self education will probably cost less than that.
That wasn't what he said, but he can certainly defend himself lol. Have you searched this forum yet for Solar City?Comment
