I am a solar fans and install a 275x8 system in my previous place in bay area, 2 years ago, at a cost of 6700 before any rebate. Now in the new place I also want to install a small 2-2.4kw system utilize a south face roof. However, all the quotes I received are quite expensive. Is there any suggestion? Where to find more cheap quotes? Any refer? Is it realistic for a 3 per watt system? the roof has easy access and is the shingle which should be easy. Many thanks!
Solar install in (torrance) los angeles
My suggestion would be to go with a larger system. Usually the fixed costs drive up the $/watt on systems less then 5kw.
Hopefully someone on the forum will provide you a possible lower cost source for a grid tie system. -
How much are you being quoted for what products ? Something like the difference between buying Hagen- Daz by the 14 oz. size for $4.50 vs. $7.00/quart, a small(er) system will probably cost more/STC Watt because of things like fixed costs (the truck needs to show up whether it's for 8 panels or 80), but oversizing would be false economy for many reasons. Just don't buy Sunpower, and don't fall for the leasing trap.Comment
currently i have several quotes, from three companies
2.4kw / 10500 solarcity
2.6kw / 9700 sunrun/costco
1.96kw/ 7800 a local installer
my installation in bay area 2 years ago is at 2.2kw / 6700
any suggestions, i thought i probably will not pull trigger at this price, where can i find relative cheap vendor for my solar effort.
Thanks!
Thanks!
For the size system you're considering and the area you're in, $3.75 - $4.00/Watt may be about the best you'll do.
I'd be more concerned about vendor quality and value for my $$ and a bit less about initial price. Buy cheap, buy twice.
Do you know what your loads are ? Having a goal helps the improve the chances of a cost effective installation.Comment
+1 above, toss SC and Sunrun. Get at least 2 more real quotes to match your 7800. Who did you use last time ? There were nonprofit groups in Bay area a couple years back that prices couldnt be beat, just a long waiting list, you couldnt compare prices against normal for profit companies.Last edited by cebury; 07-16-2017, 08:05 AM.Comment
