My Solaredge system dead. How to figure if it's an optimizer or inverter that's bad?
  • kny
    • Jul 2015
    • 74
    #31
    Originally posted by ButchDeal
    it is still too small of a wire.
    The optimizers do not report via IP. they send their data to the inverter and the inverter sends the data to the cloud.
    Yes, I know how ethernet over powerline works. My point is that the optimizer the inverters states is unreporting is still reporting data out.
    Wire probably is too small. I'll ask installer how they determined 10 AWG was ok. But, 6000/245 = 24.5 amp and assuming the SE-6000 inverter never puts out more than it's max output of 6kw, this amperage should never be exceeded, so 10 AWG over 60' is borderline bad but not egregious. An SE7600 would clearly need bigger wire with 32 amp max output.
    I'm not happy about the ungrounded optimizers and I'm not happy the AWG is at best pushing the envelope or at worst simply too small. Nonetheless, I am 98% certain my issue is a bad inverter. I just went through a full reboot cycle and all 22 optimizers came up as P_OK. It is a cloudy day, so production would be small. Yet, within 60 seconds the AC VOLTAGE TOO HIGH error came up and during that minute the VAC was 245 and the VDC was in the 440s, far higher than the normal 370 the system always ran at under all conditions.
    So, if all optimizers are reporting, something is causing the inverter to drive the system at an exceptionally high 440 volts and then shut down for high AC volts (though the screen never went above 245).
    Weird stuff (zero production periods in middle of day) was happening back on 4/11 and 4/12 and then seems to have been simply up and died.
    My installer has finally responded. So, hopefully I'll get some movement on this.
    • kny
      • Jul 2015
      • 74
      #32
      90 deg terminals don't exist in this application. 60 or 75 deg for any consumer or commercial equipment. 10 awg is not code compliant for this inverter. Hopefully the installer at least used only a 30 breaker with it, at least then the conductor is protected, and the violation shifts toward having an undersized breaker for the supply.
      Yes, 30amp breaker. It has never tripped.
        No, it wouldn't trip. The problem is that at full output, you exceed 80% of the breakers rating. That is not allowed by code.
        The inverters data log is too slow, and even the display probably doesn't respond fast enough to catch the AC voltage spike. You need professional equipment to diagnose this, but a loose connection would be enough to cause the symptoms you've seen.
        The high DC voltage is expected when the inverter stops producing power. Re-pairing the optimizers is important when not all are reporting correctly and voltage is not falling to a safe level automatically... That fixed a similar problem on my inverter.
          • 3802
          #34
          They do not use ethernet over powerline or IP at all. They do communicate over the DC power line but not via IP. You should re-pair them to the inverter or the installer should.
          Max continuous output current for the SE6000A is 25 amp so a 30a breaker is too small. (25 X 1.25% = 31.25) If they could find one they could have used a 32a breaker (unlikely) or a 35a breaker (also unlikely)
          The Inverter will have the optimizers produce higher DC voltage as needed for higher AC voltage or to produce less power etc.
          It was still a poor install back then as well.
          • adoublee
            • Aug 2009
            • 251
            #35
            Not only this this an NEC issue for wire size, but SolarEdge documentation says recommended breaker or fuse size is 35A or 40A on a 240V system.
            • kny
              • Jul 2015
              • 74
              #36
              Thanks everyone for all the informative responses. This has been educational and informative. I have lots to discuss with my installer.
              • kny
                • Jul 2015
                • 74
                #37
                So, I just opened up the breaker box and pulled the breaker for the solar. I don't know how you quantitatively measure quality of connection, but one of the two hot legs appeared mostly disengaged with only maybe 1/8" connecting. I loosened, jammed in fully, and tightened. Certainly seems like it was a poor connection. Next I'll check the connections at the ac disconnect and in the inverter, but it's raining now, so not going up on roof.
                  • 3802
                  #38
                  on the roof should be all DC.
                  SolarEdge uses spring loaded connections which are generally better than torqued connections but that all assumes they are used correctly which is certainly questionable with an installer willing to use undersized cable and breakers.
                    Yeah, even spring loaded connectors can be done wrong, especially with stranded wire. I like spring connectors, but try hard to use ferrules on all of the stranded conductors. The twin connectors are a legit way to double tap a termination otherwise rated to accept only a single wire.
                    • kny
                      • Jul 2015
                      • 74
                      #40
                      The AC Disconnect is on the roof. Right next to the inverter. If there was a bad connection likely it was the one in the breaker box that I got. But, theoretically it could be the AC disconnect, too, right? Or also the spring-loaded AC out connectors in the inverter, though unlikely.
                      Either way, the installer has created a ticket with SolarEdge, who says it is a monitoring issue only (ha!). So we will see how long all this takes to resolve, because it sure as heck is not just a monitoring issue; that I can prove with certainty. But, I've got to step back and let the installer and SolarEdge work through it their own way on their time.
                        Yes, the disconnect is another opportunity for a bad termination.
                        With a rooftop mounted inverter (which is really unconventional), have you looked at any of the temperature data to see if it is overheating? That is another reason the system could be mis-behaving.
                        Re-pairing the optimizers is something you can do yourself without opening anything up, but you do need direct access to the inverter.
                          • 3802
                          #42
                          Why is the AC disconnect and inverter on the roof? The AC disconnect should be next to the meter or at an accessable ground location.
                          The inverter would be better suited next to or near to the AC disconnect at ground level.
                          SolarEdge is responding to whatever issue the installer put in.
                          • kny
                            • Jul 2015
                            • 74
                            #43
                            When I rebooted system this morning all 22 optimizers came up as P_OK, as opposed to before reboot when one was non-reporting. If all 22 optimizers are P_OK is there any purpose to re-pairing? I have direct access to the inverter; that's not a problem, and I can surely learn how to re-pair if instructions are in an install guide. But if all 22 are on P_OK is there any purpose to it?
                            I have not looked at temperature data. It does not seem something you can chart on in the monitoring portal. I was told these things are intended to be outside in the elements and it would not be a problem. It is mounted on east wall, so is out of direct sun by early afternoon.
                            • kny
                              • Jul 2015
                              • 74
                              #44
                              The meter is inside, adjacent to breaker box. Inverter inside was not practical due to space considerations. Historic district so inverter and disconnect were placed on roof; nothing can be visible from street. AC disconnects for air conditioner compressors are on roof as well. This is why there is a 60' run from inverter to breaker box. We're getting diverted here.
                                • 3802
                                #45
                                AC disconnects for air conditioner is different from Solar.
                                Firefighters need to turn off solar immediately before doing anything on the building.
                                You have an inverter with rapid shutdown but they would have to climb on the roof and get to it to use it.
                                There should be labels indicating the location of all the solar equipment as well at ground level.
                                to answer your other question if all the optimizers are reporting then no there is no need to re-pair. I would suspect that the installer or solaredge did this remotely if it is now working.
                                you still have the wiring issues and inverter functioning issues to deal with. I would doubt that the installer mentioned the wiring to solaredge.
