My job is mostly on mechanical works. I know very little about solar panels. I've learned a lot on this forum. Pls. dont get tired on helping people like me to learn.
All of the panels I see is made to have an average otput of 18v. Some charge controllers reduce this voltage and increase the output current. If I make panels with 17v or 16v output, I could use the extra cells to build more panels and increase total current output. Will there be significant voltage drop if im having 50% light intensity or a partly cloudy day up to the extent that the voltage will not be enough to charge the battery? What is the most efficient voltage for charging my 12v battery via the controller assuming the voltage entering the controller is kept constant?
By the way, my contoller is a PWM (I think).
