  • RenewablesRock
    • Jul 2018
    • 88
    #31
    Originally posted by littleharbor
    3 200ah. batteries,.. sounds like 12 volt batteries. Unless you are building a 36 volt system this is a bad choice.
    5, 250 watt panels, not a good number. You only have two choices to wire them ALL in parallel, or ALL in series, Too high voltage unless you have a high voltage MPPT controller.
    You can combine with with series and parallel for eat set of 2 panels. What's wrong with that? For each pair I put wire in series, I get nearly 90 volts and up to 16 amps. I could just keep putting those pairs to increase the amps. Would just need more charge controllers. An order for a Midnite Solar charge controller(s) sounds like it would be in order.
    • littleharbor
      • Jan 2016
      • 1998
      #32
      [QUOTE=RenewablesRock;n381472]
      Nothing at all but what are you going to do with the 5th panel? Set it aside till you get a 6th panel?
      • RenewablesRock
        • Jul 2018
        • 88
        #33
        [QUOTE=littleharbor;n381474]
        Yeah, that causes a problem. That's why I ordered everything in pairs.
        • gendil
          • Dec 2016
          • 62
          #34
          i meant 2 batteries 200amps 12 volt 200amp 24vdc battery and c/5 of 40 amps which is suitable to work on 4 panels of 250 watt 24vdc nominal
          using mmpt my batteries will eat 40amps from the production of 4*250=1000 wattt panels
          now if we divide 1000 watt /24 = 40 or so
          1000 watt will be more than enough to run 200 watt fridge and 500 wat air conditioner
            #35
            The fridge yes. The A/C unit maybe or maybe not. The compressor on those units may have a very high starting draw which could drop the 24v battery low enough to shut down the inverter.
