I'm trying to understand how the credit for production sent to the grid is different between TOU vs non-TOU.
As I understand, I have a choice of going TOU immediately or putting it off for 5 years.
I've read everything I can find on the SDGE site, but I'm still uncertain. I know that I.m going to pay roughly 2 cents per kWh pulled from the grid due to the non recoverable costs (or whatever they are called), but let's ignore that. Under non-TOU, what's messing with me is the tiers (which is now just two tiers) that are in place. If I am non-TOU, for power sent to the grid am I getting Tier 1 credit or Tier 2 credit, and similarly in the months where I use more than I produce, am I using up the credits at a Tier 1 rate or a Tier 2 rate? Or does Tier 1 and Tier 2 not come into play, and at true up it's just net 12 months kWh user from the grid that gets paid for (again ignoring the 2 cents non recoverable costs)?
I think I've got it sort of figured out for TOU in that the credit I get is determined by the time produced and the retail rate at that time of day, and then this credit is used up by the TOU retail rate at the time of day I am pulling power from the grid. Thus if you can produce more (and use less) during peak time of day, you could size your system smaller to yield the same "true up" bill due. And hence due to TOU peak being 11 am to 6 pm (currently), changing your grid to a more westerly orientation from due south is likely a plus (providing going west doesn't make for more shading).
What's complicating my situation is I purposely wish to overproduce so that I can run my A/C more in the summer -- go from it's only run when it absolutely has to (the wife can't take it anymore
) to saying "go ahead and use it more" and trying to figure out what "more" is going to mean both in total annual kWh AND what those kWh usages might be in a TOU and non TOU scenario. My last year usage was 10,000 kWh, and I'm thinking of going with a system that will provide about 13,400 kWH -- right now my calculations show a payback of 5.3 years at 10K current usage or 3.7 years if usage was 13.4K -- this is with the non-TOU rate plan. Thus even if I didn't really need to be at 13.4K production, to me either a 5.3 year or 3.7 year payback looks attractive AND practically speaking removes the electric bill from my post-retirement budget (which is about 4 years away).
So back to my question, how exactly does TOU vs non-TOU credits work? And if you were not on NEM 1.0 and were putting your system in now, would you go TOU immediate or stay with the non-TOU rate plan while you are allowed to do so?
