  • javolt
    • Oct 2016
    Troubleshooting and fault codes
    Greetings and this will be my second post, couldn't find a thread with my question. If you have a suggestion where my topic should be please provide the link..
    I'm a grid-tied 5KW PV owner since September 2011. My system has performed flawlessly until a couple days ago it shut down - nothing was lit up on the inverter and my SMUD utility meter was not displaying. It turns out to have a blown 30 amp fuse on one of the 120 volt AC legs in the shut off switch next to the meter. Replaced it and all is good - however.... Fault code on my PVP4800 inverter reads: voltage overload - fault code 1000. I'm not sure where to post or ask the question but I'd like very much to know what would cause an event like this? Thanks
    What brand is PVP4800 inverter ? Does your manual list what that is - DC overvolt or AC line overvolt ? Have you had unusually cold weather that could have increased the PV array DC voltage above the threshold
    • javolt
      • Oct 2016
      1) "What brand is PVP4800 inverter ? Answer: StarInverter PVP4800
      2) Does your manual list what that is - DC overvolt or AC line overvolt ? Answer: Yes, AC over-voltage. I did find and correct what appeared to be a loose lug on one of the 120v leads to the main breaker. That would explain the intermittent surges with our lighting.
      3) Have you had unusually cold weather that could have increased the PV array DC voltage above the threshold " Answer: No cold weather yet, I'm in the Sacramento California area with daytime temps in the 70's. According to the specs I'm well within the max 500VDC input voltage rating.
      I will be contacting the manufacturer to find out more details. So far everything seems fine.
